Old 12-05-2012, 10:15 AM   #11
Fulltime family RVer
Oy. 10-seconds- man, that's tough!
Thanks for the info everyone.
ependydad is online now   Reply With Quote
Old 12-05-2012, 01:20 PM   #12
Herk7769's Avatar
Meh, maybe a slight exaggeration. It is a very easy mod.
HAM CALLSIGN - KC3FFW
Old 12-05-2012, 01:32 PM   #13
Lynkage's Avatar
It definitely takes longer to go get the parts than to install the valves, even if you have an HD or Lowes less than 5 minutes from your house!
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 12-05-2012, 02:12 PM   #14
kenandterry's Avatar
I don't doubt that it takes 10 seconds per valve as Herk mentioned...........but that's with help from his pipe dope friend or it woudda taken longer.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 12-05-2012, 08:23 PM   #15
So, I got the ball valves and put them into place this even. Fortunately, "Brian" at Lowes saw that I was lost in the plumbing area and was amazingly helpful. Took me right to what I needed.
Unfortunately, they both leak just a bit. The cold is worse than the warm. I don't know if I did a crappy job taping the threads or what (it was harder to get a clean/flat layer of tape than I expected). I'll try again when it's daylight or possibly try the paste. I don't know.
Oh- the original threaded end pieces had these inserts. Any idea what they are? I had to remove them to get the ball valves installed.
Thanks y'all.
ID:	22054   Click image for larger version
Old 12-05-2012, 08:29 PM   #16
Lynkage's Avatar
Try some Rectorseal. That is one of the brands Oatey is another. both are good and a bit eaiser to apply than teflon tape.
Those are compression washers/ferrules to help seal the threaded cap. discard those.
Shane & Antoinette
Old 12-05-2012, 08:44 PM   #17
Herk7769's Avatar
I highly recommend the Teflon pipe dope.
SOS Products Teflon Pipe Dope
Completely cover the male threads and screw the valve on tight.
Real important to completely cover all sides of the male threads.
Leaving gaps will cause a leak.
Old 12-05-2012, 08:51 PM   #18
Thanks Herk and Lykage, I'll look for this dope/putty at the big box stores and will redo the valves.
Old 12-05-2012, 09:47 PM   #19
herk you know it all you should openn up a camper store
jkklops is offline   Reply With Quote
Old 12-06-2012, 02:51 PM   #20
VinceU's Avatar
Thanks y'all.
Looks like ferrules or gasket installs between the outer nut and the tubing. Used in copper, plastic, stainless tubing, very common. Not the same thread as pipe fittings. I'd take all the above including the caps to Brian and explin the situ. You can also convert the Pex blue/ red tubing to pipe fittings, maybe better, he can show you how.
