Old 12-04-2012, 06:51 PM   #1
Always Learning
Sigh, lost low point drain caps (SabreSam?)
I blew out my water lines a couple of weeks ago in preparation for colder weather here. I'm starting to de-winterize it in prep for a trip in 2-ish weeks. I have found that apparently I've lost my low-point drain caps. Does anyone know what I need to get as a replacement for these?
Or, Sam, can you save me and tell me that your parts folks will ship some out for the low-low price of $20?
Thanks.
Sincerely,
A dunce
Old 12-04-2012, 07:00 PM   #2
lindy's Avatar
Go to Lowes or a local hardware store and get, 1/2" NPT ball valves. Once installed you'll never have to remove them to winterize, only open the valve.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 12-04-2012, 07:34 PM   #3
VinceU's Avatar
Low point drains
Thanks.
Sincerely,
A dunce
Quick question my drains end in a 1/2NPT plug, are yours caps instead?
No big deal, valves will fit if you insert a close nipple first if they are plugs like mine.
Old 12-04-2012, 08:24 PM   #4
3 Happy Campers's Avatar
I also installed pvc ball valves.
Also ran lengths of pvc out to the side of the 5er so I didn’t have to crawl under every time I wanted to drain.
Also put a ball valve on the fresh water tank drain.
Name:	Low Point Drains a.jpg
ID:	22037   Click image for larger version
Name:	Low Point Drains c.jpg
ID:	22038   Click image for larger version
Name:	Low Point Drains d.jpg
ID:	22039   Click image for larger version
Name:	Fresh Water Tank Drain.jpg
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 12-04-2012, 09:33 PM   #5
Herk7769's Avatar
My solution (before and after):
ID:	22042   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 12-04-2012, 10:15 PM   #6
GlacierGus's Avatar
Great idea. That is going on my "to do" list for next summer.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 12-05-2012, 09:04 AM   #7
Always Learning
My fresh water tank drain already has the valve. It was my 2 low point drains that had caps.
If I want to add these ball valves, what tools do I need/how do I do it? (Mind you, I'm a computer guy with no real handy-man ability.)
Old 12-05-2012, 09:39 AM   #8
lswartz's Avatar
You always have the best pictures which show/explain/etc. perfectly.
Thanks.
2021 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 12-05-2012, 09:56 AM   #9
Lynkage's Avatar
Were they threaded caps?
If so, then look for some threaded ball valves (should be 1/2" NPT) and you will just thread them on in place of the caps.
You will need some teflon tape (thread seal) or paste and some channel lock pliers to hold the threads on the pipe coming out of the trailer and tighten it (the Valve) about as tight as you can get it by hand. (without turning red in the face)
Wrap the teflon tape in the direction of the threads, that is clockwise, or the paste is a bit eaiser to put on. Just a bit messy.
BTW If they are like Herks pic above, the 6 flat spots above the threads is where you hold it with the channel locks.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 12-05-2012, 11:00 AM   #10
Herk7769's Avatar
I used channel lock pliers to hold the down pipe while I hand tightened the valve. I also added Teflon pipe dope to the threads before I assembled them.
Total time for mod about 10 seconds per valve.
Old 12-05-2012, 11:15 AM   #11
Always Learning
Oy. 10-seconds- man, that's tough!
Thanks for the info everyone.
Old 12-05-2012, 02:20 PM   #12
Herk7769's Avatar
Meh, maybe a slight exaggeration. It is a very easy mod.
Old 12-05-2012, 02:32 PM   #13
Lynkage's Avatar
It definitely takes longer to go get the parts than to install the valves, even if you have an HD or Lowes less than 5 minutes from your house!
Shane & Antoinette
Old 12-05-2012, 03:12 PM   #14
Kanadian Kamper
kenandterry's Avatar
I don't doubt that it takes 10 seconds per valve as Herk mentioned...........but that's with help from his pipe dope friend or it woudda taken longer.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 12-05-2012, 09:23 PM   #15
Always Learning
So, I got the ball valves and put them into place this even. Fortunately, "Brian" at Lowes saw that I was lost in the plumbing area and was amazingly helpful. Took me right to what I needed.
Unfortunately, they both leak just a bit. The cold is worse than the warm. I don't know if I did a crappy job taping the threads or what (it was harder to get a clean/flat layer of tape than I expected). I'll try again when it's daylight or possibly try the paste. I don't know.
Oh- the original threaded end pieces had these inserts. Any idea what they are? I had to remove them to get the ball valves installed.
Thanks y'all.
ID:	22054   Click image for larger version
Old 12-05-2012, 09:29 PM   #16
Lynkage's Avatar
Try some Rectorseal. That is one of the brands Oatey is another. both are good and a bit eaiser to apply than teflon tape.
Those are compression washers/ferrules to help seal the threaded cap. discard those.
Shane & Antoinette
Old 12-05-2012, 09:44 PM   #17
Herk7769's Avatar
I highly recommend the Teflon pipe dope.
SOS Products Teflon Pipe Dope
Completely cover the male threads and screw the valve on tight.
Real important to completely cover all sides of the male threads.
Leaving gaps will cause a leak.
Old 12-05-2012, 09:51 PM   #18
Always Learning
Thanks Herk and Lykage, I'll look for this dope/putty at the big box stores and will redo the valves.
Old 12-05-2012, 10:47 PM   #19
herk you know it all you should openn up a camper store
jkklops is offline   Reply With Quote
Old 12-06-2012, 03:51 PM   #20
VinceU's Avatar
Thanks y'all.
Looks like ferrules or gasket installs between the outer nut and the tubing. Used in copper, plastic, stainless tubing, very common. Not the same thread as pipe fittings. I'd take all the above including the caps to Brian and explin the situ. You can also convert the Pex blue/ red tubing to pipe fittings, maybe better, he can show you how.
