Old 03-07-2014, 10:46 AM   #1
Are we there yet.......
Pbalmer65's Avatar
Single or duel air in Sabre 36qbok?
Does it best serve me to add the second air now before summer? What temp should I expect with just the single 15 I have now?
Pbalmer65 is offline   Reply With Quote
Old 03-07-2014, 10:51 AM   #2
I cannot imagine sleeping in the heat if summer without the second a/c....but with it the room is cool and comfy!
2014 Sabre 36QBOK - 7.......sort of
dleighb is offline   Reply With Quote
Old 03-07-2014, 10:52 AM   #3
Fulltime family RVer
We have the dual A/Cs and I couldn't imagine being without. But, I don't know what the temperature (or worse-humidity) cut-off would be for when I feel like the 2nd one is required.
Old 03-07-2014, 11:02 AM   #4
AquaMan's Avatar
We have dual A/Cs on our 365saq (same basic layout), and while we don't use it all the time, one time without it, is all it takes. We spent a weekend with 95+ degree temps and high humidity, and the 15k wouldn't handle it. The following weekend I added the 2nd 13k A/C and was pleased. This was also in OH, so it's not just a "southern" thing.
Name:	iphone 7-20-13 147.jpg
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 03-07-2014, 11:07 AM   #5
Even if you don't need to run two its so nice to run the air in the room you are not in just for the noise. When sleeping we run the living room air and use a small fan. Reverse when we are up. When it gets hit then you have both. Go for it and get the 15000 BTU. I wish I had them instead of the 13500. Also if your thermostat will run dual HP I would opt for that also.
Old 03-07-2014, 12:16 PM   #6
Camper Less Camping
Cajun Po-Boy's Avatar
Second AC a must...you won't be disappointed!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 03-07-2014, 10:57 PM   #7
speedcat's Avatar
Ditto on the 2nd AC! Get it and don't look back...you wont be sorry
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
speedcat is offline   Reply With Quote
Old 03-07-2014, 11:04 PM   #8
Pbalmer65's Avatar
Thank you everyone. The ac has been purchased. Your help was convening. It's was the pic of the thermostat that did it for sure.
Old 03-07-2014, 11:50 PM   #9
Oklahoma Proud
MillerTime's Avatar
Glad you found one!
Hollar at me if you need some help with it!
MillerTime- Future Sabre Handler!!
Old 03-08-2014, 11:54 AM   #10
Definitely the right move. OK gets as hot and sticky in most of the state as Houston, maybe warmer! The dual AC units will keep you comfortable in the summer.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 03-08-2014, 12:02 PM   #11
Ford Idaho's Avatar
Second A/C, do it, might save you a hot night.
Old 03-08-2014, 12:20 PM   #12
BombDoc's Avatar
Good choice, you won't regret it. We alternate the use of ours. When we are sleeping, the living room A/C is what we use. This is because of noise. The bedroom puts out some cold air and when it cuts on and off, it's rather noisy. So we just run the living room at night and the bedroom in the day since they are all ducted together. Sometimes down here in SC, we need them both on during the day just because of the humidity.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-(20) 2019-0
BombDoc is offline   Reply With Quote
Old 03-08-2014, 12:45 PM   #13
Oklahoma Proud
MillerTime's Avatar
One 15k wasn't enough in our 34' puma in the summer, I was fixing to add a second one, but the storms came thru and totaled it just before I spent the money doing it! Got lucky!
Old 03-08-2014, 03:23 PM   #14
Pirates55's Avatar
I upgraded to the 15k in the main part of the unit and got the 13k in the front bedroom.
Pirates55 is offline   Reply With Quote
sabre
