Old 05-27-2016, 04:37 AM   #1
monde48's Avatar
Six point leveling system
Good morning I'm just wondering if someone could help me
I had the six point leveling system and a couple weeks ago I lost one of the legs
and now I have my parts and I want to fix can I manually have the middle legs, retract by themselves because that's the one I lost any help would be much appreciated please point me in the right direction thank you
monde48
monde48 is offline   Reply With Quote
Old 05-27-2016, 06:21 AM   #2
TURBS's Avatar
Middle ones will not retract by themselves to my knowledge
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-30-2016, 09:36 PM   #3
Charles.maine's Avatar
Not sure if it would help but hit retract and rear and see if you can get it to work. May have to run them out and then back in to get the right position.
2015 Chevrolet Silverado 2500HD 4x4 Z71 Duramax/Allison Combo Pull Rite, ISR Series Superglide 16K, LoadLifter 5000 Ultimate W/ WirelessOne
Current RV: 2016 Palomino Columbus 381FL Fifth Wheel
Lippert Flex Air Pin Box, LT235-85-16 GY G614
Nights Camped 2013 - 6 • 2014 - 7 • 2015 - 12 • 2016 - 29 • 2017 - 16 (17 more planned!!)
Charles.maine is offline   Reply With Quote
Old 05-30-2016, 09:50 PM   #4
I assume it is one of your middle Rams that you lost a part on? Let's assume it is on the left side. Go to you level up panel and push the up or down arrow until 'manual' is on the screen. Then press 'enter'. You are now in the manual mode. Now push the left button. The left Rams will start to extend and get them to where you need. To get them to retract, push the 'retract' button and then push the 'left' button and they will begin to retract. If you want them to go down again, press the 'retract' button again. Whenever the retract LED is lit the Rams will retract, otherwise they will extend.
Not sure if this help but it is how you manually control your Rams. You can't control the middle or rear Rams but you can control one side at a time...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 05-30-2016, 09:58 PM   #5
elrand's Avatar
so the short answer is No.
there are basically 3 systems on the 6 point. This is what i have seen on mine which is hydraulic
Front Landing gear - front 2 jacks
Street side - 2 jacks in-front and behind axles
Curb side - 2 jacks in-front and behind axles
so to work on any of the rear jacks you would have to retract them. I would hook up your truck while doing the work just encase you loose pressure on the whole system
2015 Cedar Creek Silverback 33IK
elrand is offline   Reply With Quote
Old 05-31-2016, 05:42 AM   #6
monde48's Avatar
I want to thank everyone for the reply. I will be hooking up the truck to the fifth wheel today and replacing the leg that I lost on the Highway. Once again thanks for everything
monde48
Old 05-31-2016, 05:52 AM   #7
BandJCarm's Avatar
Can I ask how you lost it? I have one and am curious....... thanks.
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 05-31-2016, 12:54 PM   #8
monde48's Avatar
Yes, you can. It was the day I picked it up on the way home. I lost one of legs and when I got under the trailer. I could see that the pin that held the legs in was sheared off and that what happened
monde48
Old 05-31-2016, 01:16 PM   #9
monde48
Are they electric or hydraulic jacks? Must be electric as I don't think there are pins holding the ram in place on hydraulic. My earlier post about using manual mode was for a LCI hydraulic system. I not sure how the electric system operates...
2016 Siverback 33IK
Old 06-02-2016, 04:43 AM   #10
monde48's Avatar
they Are electric jacks
leveling
