Old 10-03-2013, 09:42 AM   #1
treaves's Avatar
Sleeping on bed with slide out in?
I thought I had seen a similar post before, but, can not now locate it.
Does anyone know if it is safe to sleep on the bed with the slide out in? Will it damage the slide out mechanism?
2012 Ram 2500 Laramie Limited CCLB CTD
2014 Columbus 320RS
treaves is offline   Reply With Quote
Old 10-03-2013, 09:47 AM   #2
Sleeping
Yes you can sleep on bed with slide in the out position. They are made for that. If concerned about the extra weight there are jack supports you can install under the slide when in the out position.
Adrian & Cathy Perkins
2009 Chev Silverado 2500 HD
2008 Keystone Cougar 268 RLS
Papa Puttz is offline   Reply With Quote
Old 10-03-2013, 09:52 AM   #3
He said with it IN.
Old 10-03-2013, 09:54 AM   #4
AquaMan's Avatar
Pretty sure OP is talking about the slide out in the "IN" position. With that said, it depends on the slide. My bed slide has rollers under it, and is as solid in, as it is out. More than likely, your's is built the same way.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 10-03-2013, 10:06 AM   #5
If we are traveling and pull in a Rest Stop to Nap/Rest I dont put the Slides out,courtousy too others,but I still sleep/nap on the bed. The rest of the time the slide is out when bed is in use. Youroo!!
Old 10-03-2013, 10:42 AM   #6
Fulltime family RVer
As long as it's not a flush floor design, you can be on the slide when it's IN.
The flush floor slides aren't supported when they're in and can be damaged by walking on them when they aren't supported.
Most bedroom slides that I've seen aren't flush floors and are fully supported when in. (Mine, for instance. We regularly climb on/across the bed with the slide in).
Old 10-03-2013, 10:02 PM   #7
Columbus 302 rs
In storms like Hurricane Sandy we've slept on the bed with the slideout's in. No problem. We bring them in when winds are above 45-60mph.
Columbus 320rs with Ford King Ranch F350
hanging in the Shenandoah Valley and catering
to QuickSilver our 18 year old photogenic cat.
TheEdge is offline   Reply With Quote
Old 10-04-2013, 12:11 AM   #8
chiefly1's Avatar
On most of the slides you can sleep with it in just make sure it is supported. I've seen a few that floated and if you have that type you will need to support it or you could damage it. Was in AZ a few years ago during a very high wind and torrential rain storm and the prudent ones pulled the slides in. Some that didn't had severe damage and could not get the slides back in.
chiefly1 is offline   Reply With Quote
slide, slide out, bed
