Old 05-13-2019, 04:41 PM   #1
Slide Leaking AGAIN!
We have a 2018 Puma 25rkss The slide was leaking after a heavy rain last May 2018 I took it back to dealer as it was under warranty. The tech said they forgot an inner seal? in the slide. He 'fixed' it and we have had no issues since. I have it in our yard and slide was out and we had heavy storms all morning and early afternoon. Once they passed I went to check on everything and low and behold the dripping leak is back!!! it is right on the edge of slide inside at the halfway mark. I Got up on ladder and there was quite a but of water on the slide so I squeezed it off and waiting to see if that stops it. Question: What do I look for on the outside? Should I look at replacing it AGAIN!? and is that a difficult process? TIA
RobinDella is offline   Reply With Quote
Old 05-16-2019, 11:16 AM   #2
Send a message via AIM to eprovenzano Send a message via MSN to eprovenzano
1st I'd contact your dealer... 2nd I'd consider a slide topper. I have one on mine and it really does a great job of keeping water and other debris off of the slide
2013 Palomino Stampede 23S HTT
2015 Dodge Ram 1500 6" lift rolling on 35's
eprovenzano is offline   Reply With Quote
leak, slide
