Old 08-05-2017, 01:16 PM   #1
New member
Slide out
New member here, first 5th wheel owned (2014 Columbus 320RS). Had 5 motorhomes.
Same issues as others, soft floor, residential fridge loose, now living room slide won't go out. Sounds like motor running but gears slipping. Any ideas?
rmellock is offline   Reply With Quote
Old 08-05-2017, 04:12 PM   #2
Check underneath the slide and make sure the pinion gear is rotating and makes contact with the rack.
Kstedman is offline   Reply With Quote
Old 08-05-2017, 08:26 PM   #3
New member
Need to get under camper and remove vinyl barrier to expose slide motor & mechanism.
Old 08-12-2017, 01:21 AM   #4
New member
Finally got the running gear exposed. Room will not go out. Motor runs but clutch slipping. Actuator may be binding? Should I replace actuator and motor?
Old 08-17-2017, 10:04 PM   #5
New member
Replaced actuator and motor, slide out now works great.
Old 08-22-2017, 05:00 PM   #6
alsdas88's Avatar
I have a 2014 gently used unit that I picked up last year. This is good information for the eventual failure in my 5'r. Thank you for keeping us updated on your progress.
Alan
2012 Ram 3500 DRW Crew Cab, 6.7 HO Cummins
2014 Columbus M-340RK
'69 Chevy C-10, 396BB
alsdas88 is offline   Reply With Quote
slide, slide out
