Old 06-24-2013, 02:07 PM   #1
Slide Out Cutting Electric Wiring
The 5th wheel's dining/sofa slide out has a plastic strap that was intended to guide the electrical wires when bringing the slide out in. It broke early on; now the casing and a wire has been cut.
Is there a better way to fix this than the original design?
Thanks for your help!
Wanda is offline   Reply With Quote
Old 06-24-2013, 02:37 PM   #2
Send a message via MSN to Tiggerdad
Mine got busted up on a tire blowout. I drilled holes through it and used zip ties. Worked for 6 years.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
