Old 08-15-2012, 07:54 PM   #1
slide out problem
Hi when I close the slide out since a short time, sometime the fuse 30amp. Blow out at the end of the opertation'its appen 3 times now ,I replace whit a new one and it's running good .I check under ,nothing broken or loose,lubrication is ok .I have a 2010 sabre 28rets 6 . Thank's
yroberge is offline   Reply With Quote
Old 08-15-2012, 09:23 PM   #2
themiddletonz's Avatar
I had the same issue with my slide, the problem was a pinch in the electrical wire to the slide motor grounding on the frame when slide in motion.
themiddletonz is offline   Reply With Quote
Old 08-16-2012, 05:40 PM   #3
I have check that to ,nothing wrong about strapped tight . Thank's
