Old 11-13-2013, 09:47 PM   #1
mikier's Avatar
slideout
new puma 230fbs. It looks as though the slide is not adjusted correctly. I sit normal for there to be a slight varience from top to bottom and side to side?
mikier is offline   Reply With Quote
Old 11-13-2013, 10:02 PM   #2
Dave_Monica's Avatar
Welcome to the forum!
Slight variation top to bottom, side to side okay as long as the slide gasket is fully contacted whether the slide is in or out.
Dave
Old 11-13-2013, 10:02 PM   #3
AWF1945's Avatar
Are you looking from inside or out? Not sure what your saying!
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 11-13-2013, 10:11 PM   #4
Professional Curmudgeon
wrvond's Avatar
The slide itself is a square box that pretty much stays in square. However, depending on how you have it leveled, the frame of your camper can be flexed, which in turn can take the hole the slide fits in. As pointed out, as long as it seals, you are ok. However, I'd still be looking into why the wall is out of square.
2014 Coachmen Catalina 253RKS
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 11-13-2013, 10:27 PM   #5
mikier's Avatar
thanks,
when its closed, it is tighter on the top than the bottom. when its opened, there is more space between the trim and the wall on the left side. the frame is not cocked askew. al the seals are in contact
slide, slide out
