Old 07-02-2015, 06:21 AM   #11
danielabram71's Avatar
Well just to update we ordered our 2015 solaire last may and to this day we have only seen one on the road. We drove from West Virginia to Myrtle Beach travel park and never seen one. The only one we have seen was in April at natural bridge VA.
danielabram71 is offline   Reply With Quote
Old 07-15-2015, 08:17 PM   #12
267bhsk Solaire
Purchased one week ago took first trip this past weekend I have one question about the grey tanks I dumped the grey and black tank, panel then showed grey tank 2 had 2/3 full the only way to empty it was to open the black tank valve and then the small silver valve is this normal I have regular black tank handle and grey tank handle with one smaller recessed silver handle that only empties when I have the black tank open does anyone else have this type set up
vrrgd is offline   Reply With Quote
Old 07-15-2015, 08:25 PM   #13
Kash76's Avatar
I have the same thing. One gray goes out when I pull and the other has a black handle that is in front of both the black tank lever and another gray.
I am setting up for the weekend so I am lucky to have it home for a picture. Basically, gray 1 and black will not "go" if the main is not pulled. Make sense? Click image for larger version
Sent from my SM-N910V using Tapatalk
2013 Palomino SolAire 317BHSK w/Eclipse package using a ProPride 3P Hitch
2013 Ford F-150 Ruby Red SuperCrew 4x4 EcoBoost w/Max Tow, e-lock, Michelin LTX M/S2 tires, & Air Lift 5000 Ultimate w/Load Lifter
Campers: Me, DW, DD, DS
Nights camped: 2015 (4) as of 5/25 2014 (44) 2013 (26)
ProPride Review
Kash76 is offline   Reply With Quote
Old 07-15-2015, 10:21 PM   #14
pappagrif's Avatar
I have the same. If you have an outside sink it has a separate tank that feeds to the black outlet. This I the small metal valve. I purge the Black, then Galley, then my grey tank. Not sure if order is correct but cleans all out.
Sent from Pappagrif
pappagrif is offline   Reply With Quote
Old 07-15-2015, 10:26 PM   #15
Kash76's Avatar
Same
ProPride Review
camper
