Old 05-11-2012, 10:43 PM   #1
tdeal823's Avatar
Solved- fantastic fan not working in bathroom
2011 Sabre 32bhok fantastic fan in bathroom not working this year.
All the lights in the bathroom work.
The 4 amp fuse on the fan is good.
No fuses are bad in the electrical box.
Only thing I can think of is the switch on the roof vent that turns the fan on and off. Maybe that is bad?
How do I check that?
Any other ideas?
2008 Silverado 2500HD DMax LTZ cc sb 4x4 EFILive tuned, Blocked, Deleted, Rerouted and removed B&W Turnover ball and 5th Companion or Pullrite 24K, riderite 5000 airbags
2011 Sabre 32BHOK-6 most of the options
tdeal823 is offline   Reply With Quote
Old 05-11-2012, 10:56 PM   #2
TURBS's Avatar
both switches on in bathroom ?
Old 05-11-2012, 11:01 PM   #3
TURBS's Avatar
there also should be another fuse in convertor I cannot remember ?
either the case you need a volt ohm meter to make sure you in fact have power to switch coming in and goin out . then you need to check power at the switch on the fan as you saw .
Old 05-11-2012, 11:02 PM   #4
cstover's Avatar
The fan I had, I think was a create a breeze, it would not work without the switch being tripped that made sure the vent was open.
cstover is offline   Reply With Quote
Old 05-12-2012, 06:58 AM   #5
tdeal823's Avatar
Both switches are on.
I don't have a volt meter with me. Im camping right now.
I will look again at the fuse box.
I don't see a name on my fan.
Old 05-12-2012, 07:26 AM   #6
cstover's Avatar
That looks exactly like my fan. There is a switch that will only allow the fan to run if the top is open. Mine got stuck in the down position, I just had to take the screen off and reach up and (make sure fan is off!) Jiggle the popup part. Ymwv.
Old 05-12-2012, 07:45 AM   #7
lindy's Avatar
Had the same issue with mine, it was the switch under the cover up on the roof. The switch was just stuck a little P.B.Blaster on it and it freed up and solved the problem. The switch is somewhat exposed to the elements and it's a plunger type switch and the plunger gets corrided and gunked up.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 05-12-2012, 08:48 AM   #8
2007 WildCat 32QBBS
05CrewDually's Avatar
X2. On mine, the problem was the ring terminal that is on the switch. This ring terminal grounds the switch body for activation. All was accessed from the roof with the vent lid up.
05CrewDually is offline   Reply With Quote
Old 05-12-2012, 09:13 AM   #9
tdeal823's Avatar
Thank you guys so much. Got on the roof with the cover up and moved the switch up and down.
Now it Works.
Thanks again!
Old 05-12-2012, 01:15 PM   #10
cstover's Avatar
Glad it all worked out.
Old 05-12-2012, 01:26 PM   #11
TURBS's Avatar
another satisfied customer !
fan
