Old 09-18-2014, 09:19 PM   #11
Are we there yet.......
Pbalmer65's Avatar
That was very helpful thank you.....
Pbalmer65 is offline   Reply With Quote
Old 09-19-2014, 03:57 PM   #12
amxpress's Avatar
Also, drain your water heater as it can be the source of smelly water.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 10-22-2014, 03:12 PM   #13
MacDR's Avatar
I had the Sour Smell from hot water only... I learned to empty the Hotwater tank between trips... Smell was gone after a good bleaching..
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Day's Camped 2018 "14"
You can find us: Egg Harbor Campground 7/9 - 7/11
MacDR is offline   Reply With Quote
Old 10-22-2014, 10:00 PM   #14
speedcat's Avatar
Had the same thing recently. Started out sour until the water ran through the lines. Found out it was my water filter. Removed it and problem solved. I have not replaced it yet. One more trip left the first week of Nov if the weather cooperates. I am considering using an exterior filter vs the whole coach filter.
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
speedcat is offline   Reply With Quote
Old 10-23-2014, 07:04 AM   #15
MacDR's Avatar
Good thought...I was thinking about trying a filter at the water connection and the full coach filter.. But was wondering if it would bother the water pressure..
2014 Columbus 340RK
Old 10-23-2014, 08:02 AM   #16
speedcat's Avatar
The family we travel/rv with have a Heartland Landmak, a high end coach. It did not come with a whole coach filter. It comes with one that attaches externally. Gotta think thete is something to this if the high end guys are going to it. My buddy says he can not tell a difference in the water quality and its a heck of alot easier to change out. Food for thought
B&W companion
Old 10-23-2014, 12:25 PM   #17
MacDR's Avatar
Now that the issue has been resolved, I'm still trying to figure out why the sour smell mostly came from the bathroom sink... Closest to the water heater or the Filter.. Who knows..just trying to rationalize it.
2014 Columbus 340RK
Old 10-23-2014, 02:33 PM   #18
Bacteria in the water heater smells like sulfur. It is not harmful but man does it stink. Easy to sanitise.
harderd is offline   Reply With Quote
Old 10-23-2014, 02:39 PM   #19
MacDR's Avatar
Yes it does.. But we turned on both the kitchen and bathroom faucets.. And it seemed to be worse in the bathroom.. But the rear kitchen is about twenty feet further down line..
Don't want it to happen again..
Live and learn.
2014 Columbus 340RK
Old 10-27-2014, 08:28 PM   #20
BigTJohn's Avatar
Could be from water sitting in the washer lines. If you don't have a washer but have the hookup, water just sits in the lines and usually smells really bad at the nearest faucet. Flushing out the lines is really easy. Jose attached to the valve and the other end in the drain. Run the water a minute or so, flushed.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
water
