Old 09-17-2016, 03:13 PM   #1
mikejm
Stove igniter won't light any of the stove top burners. Makes the right noise but no
320 Rs
mikejm is offline   Reply With Quote
Old 09-17-2016, 03:17 PM   #2
Ford Idaho's Avatar
Does anything that uses gas work?
If so then check and see if the stove igniter is gapped close enough.
Old 09-19-2016, 02:35 PM   #3
Head Rambler
Also look at the wiring that runs from the ignitor to the burners. One of the connections may be loose and grounding out, or an igniter rod may be touching a burner.
Gotta go campin!
Old 04-26-2017, 11:40 AM   #4
Verret Catfisher
verretcat's Avatar
Also check to see if the igniter wires have a hole and are grounding to the bottom plate. I have little use on my camper and two of the wires were sparking through the insulation.
Rockwood Minilite 2306
Silverado 2500HD - 6.0
verretcat is offline   Reply With Quote
burner, light, noise
