Old 05-03-2013, 09:47 PM   #1
indycoltsguy's Avatar
Switch
I have a 2013 TT and for the life of me I cannot figure out what the switch below the thermostat goes to. It's a single switch.
The two lower switches are light switches
Thanks in advance!!
indycoltsguy is offline   Reply With Quote
Old 05-03-2013, 09:57 PM   #2
TURBS's Avatar
Picture?
Scare light?
Porch light?
Turbs
Old 05-03-2013, 10:00 PM   #3
Old 05-03-2013, 10:04 PM   #4
TURBS's Avatar
A lot of times there's ceiling lights that also have a switch right on the light if so one may be off and then the switch doesn't work.
Do you have a light that doesn't turn on with any switches but does turn on right at the light?
Turbs
Old 05-03-2013, 10:06 PM   #5
Turbs
I have tried every light. Both lower switches go to the bathroom lights.
I was worried it had something to do with the HVAC system or the water heater etc.
I walked outside and it doesn't do anything there either
Old 05-03-2013, 10:10 PM   #6
TURBS's Avatar
Have you found the wh switch?
Old 05-03-2013, 10:35 PM   #7
Rebel702's Avatar
Since the other two are for bath lights might it be for bath vent fan?
Switch for electric outlet?
Step light - inside?
Post your model so someone that has the same unit can respond.
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 05-03-2013, 10:37 PM   #8
We have a similar switch that controls an outside receptacle for the awning lights.
Sirsea is offline   Reply With Quote
Old 05-04-2013, 01:52 AM   #9
bikendan's Avatar
if you posted your brand/model number, maybe someone with the same trailer could help you more.
Palomino makes about 70 different models of TTs, for 2013.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
