Old 03-02-2019, 04:51 AM   #1
Tank sensors
So we just purchased a 2013 Palomino Solaire 297RLDS. It's in great condition and I think we got it a good price. My black tank and one gray tank read full all of the time. Is there an easy fix for this? Thanks on advance for any help.
captrcurtis is offline   Reply With Quote
Old 03-02-2019, 05:12 AM   #2
marinerjoe's Avatar
On the black tank, dump a bag of ice down the toilet and drive around. That should take care of cleaning off those sensors. Not sure how to clean off the grey tank. Maybe a dose of water softener and having it halfway full and driving around.
Joe
Current: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
marinerjoe is offline   Reply With Quote
Old 03-02-2019, 07:04 AM   #3
madatme's Avatar
i haven't tried that yet but that's what i have also read, you might get a flush wand form gander or amazon(15 bucks) and rinse out the tank really well and a couple of flushes, I did that on my previous tt and amazed how much more poop came out, rinse until clean water comes out of the dump valve
2019 FR Vibe 28RL
2018 Silverado 1500, Husky Centerline TS
3 Great Danes, 1 Weimaraner
Wonderful co-pilot
madatme is offline   Reply With Quote
Old 03-03-2019, 08:59 AM   #4
Herk7769's Avatar
Treat both tanks with Unique’s RV-Digest-It.
Use 1/2 quart in each tank; fill with warm - not hot - water and wait 72 hours. There is dried soap and other slime on the walls of the tanks that is shorting the sensors.
Dump and fill with fresh water; then dump again.
Be prepared for some nasty dumps the first two times.
Old 03-03-2019, 09:39 AM   #5
Herk7769's Avatar
That post was from my phone.
Here is some more info on fixing your indicators.
I am convinced the fault is with dried crud on the tank walls. ICE will never fix your problem; only a good soaking with a bacteria and enzyme bath will dissolve that slime. Here is a good video on the "why".
Horst Mircacle Probes - Get accurate reading on your RV's holding tanks
Herk
ID:	198025   Click image for larger version
Name:	Horst Probe Install 044.jpg
ID:	198026   Click image for larger version
Name:	Horst Probe Install 008.jpg
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (51.2 KB, 14 views)
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 11 views)
HAM CALLSIGN - KC3FFW
Old 03-03-2019, 05:33 PM   #6
Thank you everyone the bag of ice did the trick and my gray tank fixed its self
Old 03-03-2019, 05:45 PM   #7
Herk7769's Avatar
Happy to see the simple fix worked!
Should it become a frequent problem, please do try an enzyme treatment. Folks had also had good results with RID-X septic tank treatment.
Old 03-03-2019, 05:57 PM   #8
I will keep that in mind and thank you very much
Old 03-04-2019, 03:58 AM   #9
I will keep it mind thank you
tank
