Old 07-30-2014, 03:51 PM   #1
Cyoul8r's Avatar
The Dreaded Dometic AC Error Code E1
We had a recent monsoon lighting storm and my Dometic Brisk Air AC, located in the living area, is now displaying the dreaded E1 Error Code. It means the thermostat has lost communication with the control board located in the AC unit. It was not on at the time. I also have a Dometic Penguin in the bedroom and it set off the smoke alarm and will not cool anymore. I think it lost it's freon causing this. It was on at the time. I switched the two thermostats (identical) and still get the E1 code. The Penguin will run and blow air (not cold) so I'm thinking of swapping the control boards (identical) to see if it will fix the living room unit. But before I do this, does anyone know if their is a 12 volt fuse anywhere that I should be checking first? Some boards have one on the circuit board itself but I don't see one on this unit. I have checked all 12 volt fuses and circuit breakers on the power panel and all are good. Any help is appreciated. It's hot here (110)!
2012 Palomino Sabre 32RCTS-6
2012 Ford F-250 Super Duty Fx4 6.7 Powerstroke
16K PullRite SuperGlide
Air Lift LoadLifter 5000 Air Bags
Cyoul8r is offline   Reply With Quote
Old 08-03-2014, 07:49 AM   #2
daverain's Avatar
What model brisk air?
daverain is offline   Reply With Quote
Old 08-03-2014, 03:39 PM   #3
Cyoul8r's Avatar
Dometic Brisk I, 15,000 btu, 459516.701CO. Thanks for asking.
I ended up replacing the circuit board to fix it. It got fried during the storm. There was no fuse mounted to the old board.
Old 08-03-2014, 05:37 PM   #4
daverain's Avatar
Was the board actually smoked? If not, on the board at the incoming voltage point is a smd device thats the fuse. it looks like a capacitor. Thats the way it was on mine anyway.
Old 08-03-2014, 05:49 PM   #5
Cyoul8r's Avatar
Yes. It had a pretty significant burned area under one of the components on the bottom side of the circuit board. The AC was not on at the time of the lightening spike. The power of mother nature at her finest.
Old 08-10-2014, 10:44 AM   #6
mud yapster's Avatar
Mine did this and we found one of the shore power breakers tripped.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-27-2014, 07:18 PM   #7
BuckeyeChuck's Avatar
You are lucky you know how to fix things like that. I have to rely on a surge protector.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
dometic
