Old 04-11-2017, 09:38 PM   #1
thermostat: heat / electric
I have a 2017 383FB. When I set the stat to heat electric, both a/c and the floor heat comes on. The tech said it was to circulate the air better. I looked at the Colman unit data and it shows an electric heat strip. What is the cycle of operation dos anyone know the cycle?
John & Carol
2017 Columbus 383FB
1999 F550 7.3
Livingston, Texas
Cane Raiser is offline   Reply With Quote
Old 05-07-2017, 11:27 PM   #2
Sorry I have no idea. I tried electric heat & wasn't impressed. We bought a couple small electric heaters & with fireplace it heats up nicely.
loribico is offline   Reply With Quote
Old 05-13-2017, 09:04 PM   #3
Ditto, I did the same thing. I was just wondering how that or it is supposed to work Thanks
John & Carol
2017 Columbus 383FB
1999 F550 7.3
Livingston, Texas
Old 05-14-2017, 08:59 AM   #4
sgtlm17's Avatar
Is this a heat pump on the AC unit or just an electric heat strip?
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 05-30-2017, 07:53 AM   #5
we just bought the 383FB. When you say you have electric heat are you referring a system with a fan and the usual floor vents or are you referring to the propane furnace. Our thermostat allows us to choose heat or AC. Just curious if these came with in floor heat or electric furnaces>
condojj48 is offline   Reply With Quote
Old 05-30-2017, 09:22 AM   #6
sgtlm17's Avatar
No electric furnaces. Some ac units have a heat pump or heat strip.
2011 Jeep JK Toad
Old 05-30-2017, 09:26 AM   #7
Thanks, I was not aware a heat pump is an option.
electric
