Old 09-05-2014, 05:27 PM   #1
Cyoul8r's Avatar
Tire Replacement Dilemma
I posted on 9-3-14 about my "China Bomb" blowout incident and now have a posing situation as to what tire I should use for replacement. I was seriously thinking of going with LT tires (LT235 /85 R16) as suggested but they have a diameter of 31.8". The diameter of the ST235 /80 R16 tires I am replacing is 30.8". I realize that is only 1" larger per tire and would net out to 1" of spacing lost between the two tires. The current spacing with the STs is about 1 3/8" - 1 1/2". Doesn't look like a plan and I'll just have to stay with STs.
I have a 2012 Sabre 32RCTS w/6,000 lb. axles. Has anyone having this idendical trailer been successful in coverting to LTs? If not, what did you do?
2012 Palomino Sabre 32RCTS-6
2012 Ford F-250 Super Duty Fx4 6.7 Powerstroke
16K PullRite SuperGlide
Air Lift LoadLifter 5000 Air Bags
Cyoul8r is offline   Reply With Quote
Old 09-05-2014, 06:02 PM   #2
ddphillips52's Avatar
Try some LT245/75/16's. They're about the same height as you have now and are about .4" wider.
Dennis, Linda, and Scout the Dog
2015 Mesa Ridge 347 RES
Husky 16KW with Reese Sidewinder
2013 4WD RAM 3500 Cummins TD SBCC
ddphillips52 is offline   Reply With Quote
Old 09-05-2014, 07:30 PM   #3
amxpress's Avatar
I installed Maxxis M8008 ST tires on my Columbus. I compared one next to one of the China bombs I took off. I couldn't believe the difference! The Maxxis is much heavier. The sidewall did not flex any near as much as the Akuret tires I removed, being much thicker. I couldn't afford the Michelin Ribs LT tires. I'm very happy with the Maxxis. Oh, be sure to have your new tires balanced.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 09-05-2014, 07:36 PM   #4
ryand's Avatar
I second the Maxxis tires. I too am very happy....went up a load range and feel much better about dragging the rv around now. China Bomb tread wore off within 1200 miles.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 09-06-2014, 12:11 AM   #5
Space between my tires
I have what is labeled as a 2014 32 RCTS-6. I took delivery in July 2013 so I guess they can call it what they like. I have 4 inches between my tires. I wonder if that is because I have the Equa-Flex suspension.
The attached document is put out by Carlisle Tire. I understand they do not manufacture car tires so they probably have some kind of agenda but this is their marketing on ST Vs LT tires. Have no idea if it is correct so please do not shoot the messenger. I had Carlisle's on my last travel trailer and they worked well.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-06-2014, 05:53 AM   #6
M109Rrider's Avatar
245/75/16 load E lt's is what I replaced my 235/80/16s with. Used Mesa (Cooper) ap 2's from a local Merchant/Big O for $150ea mounted.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 09-06-2014, 06:52 AM   #7
cpaulsen's Avatar
Used LT245/75/R16 Goodyears on mine to replace the 235/80/16's on mine.
cpaulsen is offline   Reply With Quote
Old 09-06-2014, 06:55 AM   #8
rattleNsmoke's Avatar
X2 on Coopers. I've run SRM II's for the last three years. 10,000+ miles and they look and behave like new.
rattleNsmoke is offline   Reply With Quote
Old 09-06-2014, 07:01 AM   #9
Rrickim63's Avatar
I've had Carlisle for years, no problems at all
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 09-06-2014, 07:10 AM   #10
Salt Shaker's Avatar
I will be replacing my " china bombs" with LTs within the 2 year time frame. I have exploded STs all over the south/southwest.
Honestly, I haven't looked at the maxxis. I will do my research then but I am pretty set on dumping any ST from china.
-said the man who's has 12 trailer tires to deal with.
Salt
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
Salt Shaker is offline   Reply With Quote
replacement, tire
