Old 08-10-2013, 10:19 PM   #1
RRSCOTT's Avatar
Tires
Our 2009 259RBSS came with 5 bolts rims with 205/75D15. The later ones came with 6 bolts rims with 225/75R15. Going to need tires soon, it ok to put 225/75R15 on the 5 bolt rims?
Randy
2009 Puma 259RBSS
2003 Chevy Silverado 2500HD
RRSCOTT is offline   Reply With Quote
Old 08-10-2013, 10:37 PM   #2
Dave_Monica's Avatar
The 225/75/R15 tire will fit on the 5 bolt rims if they're the correct diameter. For a 205/75/R15 tire, the required rim width is 5 - 6 1/2" according to the Goodyear Martathon tire specs. For a 225/75/R15 tire, the required rim width is 6 - 7". The rim width should be shown on your axle and weight sticker on the left-front of the camper...something like 15 x 6JJ for a 15" diameter, 6" wide rim.
Dave
Old 08-10-2013, 11:04 PM   #3
Just a member
kandl's Avatar
Originally Posted by RRSCOTT View Post
...it ok to put 225/75R15 on the 5 bolt rims?
If your wheels are 15x6 you should be good to go. I suspect they may be 15x5 based on your currently installed tire. That's a little narrow for a 225 mm tire. If FR is putting beefier wheels and skins on the current version of your FW, I'd want to know right away what's up with that! Are your current wheels overloaded?
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 08-11-2013, 06:14 AM   #4
RRSCOTT's Avatar
I never thought about rim width. We always thought the tires looked too small under there. The spare tire and rim that I later got looks wider, but it's a radial. Maybe that rim is wider.
Randy
2009 Puma 259RBSS
Old 08-11-2013, 07:09 PM   #5
RRSCOTT's Avatar
I checked the sticker and it said the tires are 205/75D14 and the rims are 14x 5.5JJ, but the tires that are on it are 205/75D15's.
Randy
2009 Puma 259RBSS
Old 08-11-2013, 09:16 PM   #6
For whatever reason, they've upsized the wheels/tires. If you can removed one of the wheels, the size may be on the back of the wheel ie 15 x 6JJ. The size is part of the casting on one of the spokes on our aluminum wheels.
Dave
tire, tires
