Old 04-26-2013, 12:28 PM   #11
Fulltime family RVer
Originally Posted by Davidceder View Post
I guess I am trying to find out exactly which tires (size), manufacturer and load rating are standard on the Sabre 32RCTS. I know they are 16inch "E" but that is all I know. I just want to make sure they are up to the task or negotiate something with my dealer. The GVWR of this rig is 13,890 and the rig has 6,000 lb axles so that does not compute for me. 7,000 lb axles are a $856.00 option. Is there any cause for concern regarding the Axles?
In my unscientific opinion - I'd opt for the upgraded axles, even if you aren't carrying the extra weight. I'd rather have beefier parts carrying the stuff than less beefy parts. Not that there's anything wrong with the 6k axles. It's cheap to add now - I see little to no reason not to do it. (I've been wrong before, though!)
Old 04-26-2013, 12:59 PM   #12
Camper Less Camping
Cajun Po-Boy's Avatar
Can anyone out there tell me the make and load index on the 16 inch E rated tires that are supposed to come on this unit?
Our unit was purchased Sept of last year...this is what came on it:
Westlake Super ST235/80R16
Load Range E
Cold PSI 80lbs
Max Load Per Tire: 3520lbs
So far these tires are doing great, best camper tires I've gotten when buying a new rig...hope this helps!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 04-26-2013, 03:57 PM   #13
BombDoc's Avatar
David,
Here is what I have, unit purchased 9 March 2013:
Westlake Super ST 235/80R16
Max load 3520 @80psi
Tread 2 polyester + 2 steel plies + 1 nylon
Sidewall 2 polyester
Nitrogen filled
Made in china
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is online now   Reply With Quote
Old 04-26-2013, 04:41 PM   #14
TURBS's Avatar
Davidcedar,
I found out from a very reliable source that the 7k axles are NOT an option for the 32 rcts.
You cannot even order them to be put on.
The 36qbok and anyother 36 models are the only ones to get that option.
Your dealer is mistaken that they can be ordered as an option.
Turbs
Old 04-26-2013, 05:25 PM   #15
^^^ the order form that I last saw said that the 7k axles can only be ordered on specific models. But I don't know which it says.
Old 04-26-2013, 05:28 PM   #16
TURBS's Avatar
The 36qbok is the only model that the 7k axles can be ordered for.
