Old 04-26-2013, 10:31 AM   #1
Tires on a Sabre 32RCTS
Can anyone out there tell me the make and load index on the 16 inch E rated tires that are supposed to come on this unit?
Davidceder is offline   Reply With Quote
Old 04-26-2013, 11:09 AM   #2
wmtire's Avatar
David, are you referring to a load index number used on passenger tires....ie, 87, 88, 89 etc?
Light truck (LT) and Special Trailer (ST) tires use a Load Range letter which is E in your tire above.
A Load Range E (which is 10 ply rated) varies depending on the size (and can a little on brand):
Common sizes in Load Range E:
LT 235/85R16 = 3042 pounds
LT 225/75R16 = 2680 pounds
ST 235/85R16 = 3640 pounds
ST 235/80R16 = 3420 pounds
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
Old 04-26-2013, 11:23 AM   #3
Tires & Axels
I guess I am trying to find out exactly which tires (size), manufacturer and load rating are standard on the Sabre 32RCTS. I know they are 16inch "E" but that is all I know. I just want to make sure they are up to the task or negotiate something with my dealer. The GVWR of this rig is 13,890 and the rig has 6,000 lb axles so that does not compute for me. 7,000 lb axles are a $856.00 option. Is there any cause for concern regarding the Axles?
Any additional info is appreciated
Thank you
David
Old 04-26-2013, 11:46 AM   #4
BombDoc's Avatar
I am not near my 5'er at the moment. I can tell you what tires I have make and model on my 32RCTS when I get home later today. I purchased it in March and its a 2013.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-(20) 2019-0
BombDoc is offline   Reply With Quote
Old 04-26-2013, 11:51 AM   #5
TURBS's Avatar
Thank you
David
thats becuase theres almost 2000 lbs on the pin is why it doesnt compute.
13890 - 2000= 11890 2-6000 lb axles= 12000
Old 04-26-2013, 12:03 PM   #6
Actually, 2000 pin weight should be absolute minimum. It's normally going to be more like 2500, and could be 3450, so Turbs is right: 6000 is enough.
I wonder why they give you an option for higher rated axles. It's like they're saying "We think the 6000's are ok, but we're not sure." Either they are or they aren't!
Old 04-26-2013, 12:07 PM   #7
slide5r4fun's Avatar
We've got a 2012 32RCTS. It's in storage so I can't give you the specific tire size. They are 16's and the brand is Akuret.
By the way, congrats on your "soon to be yours" Sabre. We love ours, hope you enjoy yours.
Kevin & Janine
2019 F350 Lariat DRW
2020 Jayco Pinnacle 36KPTS
slide5r4fun is offline   Reply With Quote
Old 04-26-2013, 12:07 PM   #8
TURBS's Avatar
that camper has almost 4000 lbs of capacity as well !
I think youd be hard pressed to add 4000 lbs to it as normal average user added weight is about a 1000 plus any dealer add ons like propane tanks/propane, battery and such.
sabre uses a 10" NON fabricated I beam which is one reason I purchased it.
Old 04-26-2013, 12:16 PM   #9
Axles & tires
Thanks f1100turbo, mystery solved. I will get the hang of al htis. Going from a Jayco 25 ft trailer to the 32 RCTS. Ordered a spanking new F-350 Lariat Desiel on Monday.
BombDoc, Thanks I will await the info
David
Old 04-26-2013, 12:18 PM   #10
Axles & Tires
Hence my confusion about the axle. I don't know why there is a 7,000 pound option either.
Old 04-26-2013, 12:28 PM   #11
Fulltime family RVer
In my unscientific opinion - I'd opt for the upgraded axles, even if you aren't carrying the extra weight. I'd rather have beefier parts carrying the stuff than less beefy parts. Not that there's anything wrong with the 6k axles. It's cheap to add now - I see little to no reason not to do it. (I've been wrong before, though!)
Old 04-26-2013, 12:59 PM   #12
Camper Less Camping
Cajun Po-Boy's Avatar
Our unit was purchased Sept of last year...this is what came on it:
Westlake Super ST235/80R16
Load Range E
Cold PSI 80lbs
Max Load Per Tire: 3520lbs
So far these tires are doing great, best camper tires I've gotten when buying a new rig...hope this helps!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 04-26-2013, 03:57 PM   #13
BombDoc's Avatar
David,
Here is what I have, unit purchased 9 March 2013:
Westlake Super ST 235/80R16
Max load 3520 @80psi
Tread 2 polyester + 2 steel plies + 1 nylon
Sidewall 2 polyester
Nitrogen filled
Made in china
2013 Sabre 32RCTS-6
Old 04-26-2013, 04:41 PM   #14
TURBS's Avatar
Davidcedar,
I found out from a very reliable source that the 7k axles are NOT an option for the 32 rcts.
You cannot even order them to be put on.
The 36qbok and anyother 36 models are the only ones to get that option.
Your dealer is mistaken that they can be ordered as an option.
Turbs
Old 04-26-2013, 05:25 PM   #15
^^^ the order form that I last saw said that the 7k axles can only be ordered on specific models. But I don't know which it says.
Old 04-26-2013, 05:28 PM   #16
TURBS's Avatar
The 36qbok is the only model that the 7k axles can be ordered for.
