To Any Sabre 34TBOK owners
I'd like to know if your living room slide is setup the same as mine.
My table is not even close to being level, almost one inche from the inside (high) to the outside (low).
Just wondering if someone could measure the floor lenght inside, from the corner of the slide to the edge of the OSB board.
I noticed that i am unable to see the white molding that you normally see under the carpet of your slide. All the slides i've seen the osb edge slides down past this molding. Mine sits on top and even extends over the molding.
Trying to figure out if my osb board is the incorrect lenght or i just need an adjustment to my slide.
