The toilet has to be replaced and there is no water shut off.
However, we found that Home Depot had a PVC plug for the threaded end that goes into the water valve - it was literally a 85-cent item. We had to use one this past spring when our water valve had broken due to freezing. It got us through a long weekend until the RV stores opened up.
For the toilet, call Dometic and they can either ship you one directly. Or, if you know a mobile RV tech, they can coordinate with them to get you the toilet. Dometic is fantastic to work with.
For what it's worth, I had the exact same issue with both of our toilets - leaking or separating around the seam. Both have been since replaced.
