Old 01-26-2016, 03:22 PM   #1
Charles.maine's Avatar
Took delivery today
Today was the big day. Took delivery of your new 2016 Palomino Columbus 381FL. Truck pulled it like a dream. I mean I could tell it was back there but no issues getting up to 65. Of course I wanted to be safe so the first stop was the scales. Now I will say the first one I stopped at I screwed up and pulled too far forward. The guy barely spoke English so I just took the numbers and then reweighed it when I got home. Now these weights are straight after leaving the dealer. There is nothing in the trailer. We never haul water/grey/black either.
First weigh:
Steer Axle: 10720
Drive Axle: 00000
Trailer Axle: 10480
Gross Weight: 21200
2nd weigh:
Steer Axle: 4600
Drive Axle: 5780
Trailer Axle: 10500
Gross Weight: 20880
Tires on the trailer are "Westlake" ST235-80-16 and Sumec Wheels. I cannot find anything stamped on the wheels for maximum air pressure.
TV tires are Nitto Terra Grappler G2 LT305-55R20. Maximum weight is 3195 lbs at 65 psi.
Of course weight and tires are my concern now. What are you guys thoughts on weight and tires?
2015 Chevrolet Silverado 2500HD 4x4 Z71 Duramax/Allison Combo Pull Rite, ISR Series Superglide 16K, LoadLifter 5000 Ultimate W/ WirelessOne
Current RV: 2016 Palomino Columbus 381FL Fifth Wheel
Lippert Flex Air Pin Box, LT235-85-16 GY G614
Nights Camped 2013 - 6 • 2014 - 7 • 2015 - 12 • 2016 - 29 • 2017 - 16 (17 more planned!!)
Charles.maine is offline   Reply With Quote
Old 01-26-2016, 03:26 PM   #2
Forgot to add the photo of course...
Old 01-26-2016, 03:29 PM   #3
Took delivery today
Beautiful truck and even nicer rv!!
About the weight, I'll let the 5'er experts weigh in on that! (Pun intended).
getsum is offline   Reply With Quote
Old 01-26-2016, 03:37 PM   #4
TURBS's Avatar
Took delivery today
Do they make your tv tire in a E ?
Nice Columbus!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-26-2016, 04:43 PM   #5
Not that I am aware of. Those are 20's and I could go to 18 inch Michelin LTXs and they would be 3525 a tire.
Old 01-26-2016, 05:14 PM   #6
Great looking combo! Congrats!
Old 01-26-2016, 06:43 PM   #7
WOW! Nice! I was reading your weights going "dang that's heavy wth is that...?" then saw the pic! Super nice big ole' 5er you got there!
2012 Ford F-150 3.7L V6 -- SOLD
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 RAM 1500 5.7L V8
2015 Coachmen Freedom Express 292BHDS
Loraura is offline   Reply With Quote
Old 01-26-2016, 08:10 PM   #8
Couple more from today
Old 01-26-2016, 08:15 PM   #9
Bowhnter's Avatar
Nice, congrats!
Mike and Susan
Cavalier King Charles - Jack (4) and Sadie (3)
2015 Columbus 320 RS
2017 Ram 3500 6.7 Diesel
Bowhnter is offline   Reply With Quote
Old 01-26-2016, 08:56 PM   #10
NICE OUTFIT!
I am far from the weight police but to answer your question, you are probably over your Truck's Gross Vehicle Weight Rating and Gross Combination Vehicle Weight.
My 2011 2500 Duramax has these ratings:
GVWR - 9900 LBS.
FRT AXLE - 5200 LBS.
REAR AXLE - 6200 LBS.
Advertised Trailer Max = 17,300 LBS.
These are visible on the inside of your door and stated quite clearly as to what YOUR truck is rated for. Assuming it hasn't changed much since 2011, given the above numbers and your scaled numbers you are already over without loading.
Up to you if you want to worry, you will get varied opinions on many forums. I'm aware that we are close but not losing sleep over it. 98% of our towing is currently in the prairies and the truck handles it like a complete dream. If we choose to head out across the country then I'll review the weights and maybe address it. Others will tell you that you have to have a Peterbilt or a Freightliner to pull that trailer.
But, you did ask
sabrecanuck is offline   Reply With Quote
