Old 11-01-2012, 10:11 AM   #1
Cyoul8r's Avatar
Torque for Trailer Wheels
I have a 2012 Palomino Sabre 32RCTS and would like to know what the torque rating is for the trailer wheels.
Cyoul8r is offline   Reply With Quote
Old 11-01-2012, 10:17 AM   #2
You should have received a trailer axle book that will give you the correct nut torque. It all depends on what axles and rims you have on your trailer.
Len & Cheri is offline   Reply With Quote
Old 11-01-2012, 10:37 AM   #3
H2oski
Here is what the manual says.
Wheel Stud Torque Sequence
Size Size 1st Stage 2nd Stage 3rd Stage
14” 1/2” 20-25 50-60 90-120
15” 1/2” 20-25 50-60 90-120
16” 1/2” 20-25 50-60 90-120
16.5” x 6.75” 1/2” 20-25 50-60 90-120
16” 9/16” 20-25 60-70 120-130
16.5” x 6.75” 9/16” 20-25 60-70 120-130
17.5” w/long nut 5/8” 50-60 100-120 190-210
17.5”w/flange nut 5/8” 50-60 150-200 275-325
14.5” Demount 1/2” tighten sequentially to 85-95
All torques in FT LBS.
If you don't have the manual there is one in the files section, or you can PM me.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 11-01-2012, 10:45 AM   #4
Cyoul8r's Avatar
Thanks for the quick respones. I should have been more specific. I bought this unit slighty used and did not get a manual. It has the 16" E-rated,
8 lug Sumec aluminum wheels w/6000 lb. axles.
Old 11-01-2012, 11:31 AM   #5
Stud size is the determining factor. With alum wheels, it will take at least 3 times with 50-100 miles between torqueing to get the nuts really seated.
Old 11-01-2012, 07:50 PM   #6
amxpress's Avatar
Click here for a free owner's manual:
Palomino RV - Manufacturer of Quaility RVs since 1968
Good luck.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 11-01-2012, 09:08 PM   #7
ironj's Avatar
My dealer was kind enough to put a sticker above the axles with the torque value he used, the date, and his name......
It was 120....fwiw....
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
