Old 04-27-2015, 12:58 PM   #11
Witch Doctor's Avatar
I also have the flow thru sensors 507, but I have a question my little red light blinks on the monitor all the time is that normal or do I have something inputted wrong?
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-13-2015, 07:25 AM   #12
I had the same problem. Called the manufacturer and found out the low pressure parameters were too high. He walked me through how to set that up and it solved the problem.
Captcharles is offline   Reply With Quote
Old 05-13-2015, 07:34 AM   #13
Hi,
I have the flow through, and like them for a variety of reasons -- peace of mind being the most prominent.
It is interesting to me that when I first start out in the morning -- no matter the outside temperature -- that the pressures are all about 6-8 pounds lower than the pressure I know is in the tires. Within 15 minutes, all of them read in the proper range and stay there.
FWIW.
Rich Phillips
richp is online now   Reply With Quote
Old 05-13-2015, 07:48 AM   #14
Should not have any lights blinking. You have either temp or pressure set too low. It should flash T or P if you look real close. It is pretty hard to read.
