07-10-2018, 08:47 PM
#21
Originally Posted by kenenn
Also, Keep in mind that a turn on an elevated ground area, can increase the chance of contact between the truck and camper the same as/ or more so than just a straight turn on level ground Just ask me how I know and I do have a slider.
Great point![emoji6]
07-10-2018, 10:19 PM
#22
Originally Posted by B and B
The best solution for 6.75 ft box is a Reese Sidewinder. With my 88 degree turn cap on my Heartland Bighorn and the Reese Sidewinder I can turn a full 90 degrees. Do I normally, No! I do have a tight storage spot and having the ability to get it close to 90 helps are times.
Originally Posted by NMWildcat
X2. Sidewinder is the best option for shorter beds in my opinion. Sliders are too heavy, take up too much bed room, and seem to bind up when you need them most.
Investigate the sidewinder by Reese with the air option. Perfect solution.
X3--With Sidewinder in Short Bed and square-corner 5er I can still turn well past 90 degrees. Wildcat points out the considerable disadvantages of sliders.
07-10-2018, 10:28 PM
#23
The front cap on our 5'er is somewhat "cab friendly", the pin box is somewhat long (TrailAir), the TV has an 8' box, and there is plenty of clearance between the bedrails and the trailer.. Still, when in doubt one of us will get out and act as a spotter.
2017 Riverstone 38FB Legacy
2018 F450
07-10-2018, 10:36 PM
#24
Denver To Yuma In 90 Days
My 5'ver has the 90 degree turn radius corner as well...
But I've come pretty close a couple of times.
07-10-2018, 10:52 PM
#25
I have a PullRite hitch it automatically slides so I never have to remember to unlock the slider. Not recommending any brand but get a automatic slide hitch it is worth the peace of mind and insurance deductible.
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
07-10-2018, 11:06 PM
#26
I skipped that slider for two reasons...
1) Bigger than my wallet!
2) Damn thing weighs a ton...
07-11-2018, 03:37 AM
#27
We too now have a Reese Sidewinder, LOVE IT!
We used to have a slider but it was a PITA. Had to get out, put down landing gear to take weight off pin, activate the slide handle, pull forward, latch slider and repeat the process.
Now, I take the sidewinder apart at the beginning of the camping season and grease it, put it back together (about 1 hr work) and we are good to go.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
07-11-2018, 07:06 AM
#28
Originally Posted by gentle_1ben
Interesting, I have wondered about the short beds and 5ers. I watched them in the campgrounds and they looked like an accident waiting to happen on the turns.
Ben
Those short bed/fifth wheel setups can still jack-knife sharper than the typical TT setup. Also unlike a TT, the point of contact is clearly visible from the driver's seat. So, in theory they are less accident prone that a TT setup. And to repeat, jack-knife a long bed/fiver setup just slightly more than 90 degrees and you will still have an accident.
Larry Day, Texas Baptist Men volunteer since '01
'13 Silverado LT 3500HD D/A CCSB 2wd, custom RKI bed
'17 Puma 351THSS toyhauler
07-11-2018, 04:17 PM
#29
Interesting, I have wondered about the short beds and 5ers. I watched them in the campgrounds and they looked like an accident waiting to happen on the turns. I have always had 8' beds on my older trucks. I have 60" cab to axle and a flatbed on my 2013, so 90's are easy.
Ben
SHORTBEDS ARE GREAT WITH 5ERS
With an older rig you may need a Sidewinder. I can go way past 90 degrees.
IF YOU TURN MORE THAN 90 DEGREES, YOU AREN'T DOING IT RIGHT!
I don't need no stinking longbed.
07-11-2018, 05:09 PM
#30
Well..... let me introduce you to the advantages of a long bed. After towing a fiver for five years and over 100,000 miles with a short bed, I have found the light! All I can say is WOW. The improvement in ride comfort is amazing. It is so much more comfortable that I would never go back to a short bed truck. Yes, the short bed truck would fit in the garage. Now I will buy a cover for it and leave it outside. I am now a believer. 176" wheel base, full four door and a 48 gallon fuel tank. It's all good.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
07-11-2018, 07:00 PM
#31
We have the same truck. Installed the slider hitch and it works. Only drawback is on ours it needs adjusting from time to time, just one bolt no problem. The other is you must be in a straight line to hook up or unhitch.
07-11-2018, 07:33 PM
#32
Dont trust what the salesperson tells you ever.
Do your homework first as your now doing.
Get a slider hitch.
07-11-2018, 08:00 PM
#33
Didn't have the option for a short bed and didn't want it. Carry 42 gal black tank, a bottle and floor jack, 2 - 2000 watt gens and a large plastic tool tote. Still will have room for a 5th wheel hitch unless an aux fuel tank is added. By the way, bought a CalMark cover for the truck and TT. Whatever cover you buy make sure it's Sunbrella material, FL sun is brutal but it will last many years.
07-12-2018, 06:17 AM
#34
Same here!!
07-12-2018, 02:48 PM
#35
All good for YOU, NOT for ME, Thanks for trying.
07-12-2018, 02:50 PM
#36
Get a slider hitch.
Or a Sidewinder if you prefer light and simple to heavy and complex.
07-16-2018, 06:45 AM
#37
every full size pickup I have owned was a 8ft box and that's the only box I will have
07-16-2018, 07:14 AM
#38
Point #1's not always the case. Surprisingly, the Demco Autoslide was actually the cheapest option for me. Here's what my dealer quoted me:
Demco Autoslide: $2K
Manual Slide: $2.5K
Non-Slide and Convert pin to the Reese Sidewinder: $3.5K total
I'm happy with the Demco so far, but in reality, I would have preferred the Reese. Your point #2 is spot on, these things are freaking heavy. It's been riding in the bed since the day it was installed. If I ever did need to pull it out, I'd probably have to swing by the in-laws shop so I can borrow their forklift for it.
07-16-2018, 06:32 PM
#39
I have a 3500 RAM with an auto slider pulling a 40 ft
Cardinal. No problem. Works great.
07-16-2018, 06:50 PM
#40
Manual Slide: $2.5K
Don't know where your dealer got his numbers, but I figure he had a Demco autoslider in stock to sell
My sidewinder with air ride was $850 installed after shopping around. Of course I already had a standard hitch, but they are cheaper also.
Just so other folks reading don't think those are real life numbers.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
