Old 08-13-2016, 12:36 AM   #21
scbrown063's Avatar
Originally Posted by Airdale View Post
Did you have problems with your original tires? If not, why not just use them again and to feel more comfortable increase the load range up one letter, if possible.
No problems with them yet. I've put about 4000 miles on them in the first year and still going. I just like to be informed with as much info as I can do when it is time to replace them, I can get the best. Thanks
Sent from my LG-H810 using Tapatalk
scbrown063 is offline   Reply With Quote
Old 08-13-2016, 06:10 PM   #22
I have been in large RV travel trailers and 5ers. I have had nightmares with ST tires and changed several years ago to LT BF Goodrich Commercial TA's and have pulled them 1000's of miles with no incidents. This is my recommendations.
Kstedman is offline   Reply With Quote
Old 08-13-2016, 06:15 PM   #23
Airdale's Avatar
Common sense supports your claim as your axles are rated 5200#.
USN - RET
DOD - RET
SSA - RET
Airdale is offline   Reply With Quote
Old 08-14-2016, 06:30 PM   #24
amxpress's Avatar
Three free pieces of advice:
1) Install a set of Maxxis ST M8008 tires
2) make sure they are balanced
3) install steel valve stems
4) run at maximum pressure on the tire
I know that's 4, but I remembered the last one.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 08-16-2016, 03:03 PM   #25
Originally Posted by jonwisconsin View Post
If you're going to use LT, make sure the weight specs can handle the total load. Some can't
Not sure I follow. Every tire purchase, be it P, LT, ST, etc.... must be able to handle the load.
Why would LT be any different.
The funny point of all this is, the ST's can't hold up to their sidewall markings.
People get worried about LT conversions even though they are clearly superior to the ST's they are replacing.
I'm getting a bit off topic and not replying to anyone specific, but I find it amusing of all the ST defenders. They say this is to blame:
Low pressure
Driving to fast
Abuse by delivery
UV rays (aghast!)
Blah, blah, blah
If it were those causes above, and nothing to do with junk China bombs, we would be seeing passenger tires blowing up EVERYWHERE. With the number of cars on the road, we should be seeing tire blowouts every mile...
325BH is offline   Reply With Quote
Old 08-16-2016, 03:36 PM   #26
Airdale's Avatar
Originally Posted by 325BH View Post
Low pressure (All cars since 2007 have low pressure warning systems)
Driving to fast ((Cars have much higher rated speed restrictions)
Abuse by delivery (Cars are delivered by some sort of carrier)
UV rays (aghast!) (Cars stay in motion too much to be bothered by it)
Blah, blah, blah
Car tires are hardly ever in "drag" mode.
USN - RET
DOD - RET
SSA - RET
Old 08-16-2016, 04:12 PM   #27
From Mark Polk at RV Education 101:
"When tires sit still, as when a motorhome is in storage, they start to dry out and age faster.
Weather cracking or checking occurs on all tires when they are exposed to heat and sunlight. This is especially true of a tire’s sidewall.
Ozone in the air and UV rays from the sun shorten the life of your tires. It’s not uncommon to see motorhome tires with low mileage and plenty of tread that are ruined by the effects of ozone and UV rays. Ozone and UV rays cause tires to weather crack and dry rot. This damage occurs faster in tires that are not used much."
Ref: https://www.fmca.com/motorhome/polks...ome-tires.html
"Retirement is the best job I ever had!"
2016 Rockwood Signature Ultra Lite 8244WS 5th Wheel; 2015 Ram 2500 4x4 CC-SB 6.7L CTD
Sold: 2012 Rockwood Mini Lite 2109S
fanrgs is offline   Reply With Quote
Old 08-16-2016, 04:52 PM   #28
Because free-wheeling is so much harder on tires...
Put some LT tires on your trailer and quit worrying. Getting rid of ST's are the best thing one can do.
Old 08-26-2016, 05:12 PM   #29
CWG
Originally Posted by windsurfdog View Post
The most important 4 letters when talking trailer tires:
TPMS
Just finished a trip on West Lakes from Florida to Nevada and then back to Eastern Canada and these tires have shown very little wear especially for travelling on very hot highways. But, I have purchased a TPMS to install before we depart for the migration south for peace of mind. Saw a family on I10 in Texas with a brand new Montana that had a blowout and the damage was unreal.
2017 Columbus Compass 340RKC
2003 GMC Seirra 2500HD 4x4 Duramax
CWG is offline   Reply With Quote
Old 08-27-2016, 08:17 AM   #30
Airdale's Avatar
To bad tire manufacturer's wont agree to that when it comes time to replace original equipment ST tires.
USN - RET
DOD - RET
SSA - RET
tire, tires, trailer, travel, travel trailer
