Old 08-08-2016, 01:42 AM   #1
Travel Trailer Tires
Hey guys. Just curious what tired you all recommend for when it's time to replace the factory ones. I've heard nightmares about "China Bombs" and so I was wondering which are the best.
Steve
scbrown063 is offline   Reply With Quote
Old 08-10-2016, 07:14 PM   #2
Hello,
We have Westlake on our unit currently and have driven approximately 3,000 miles over that past three years. No issues.
On our previous camper, we went approximately four years with Carlisle and then replaced with Maxxis for another four years, also with 3-4,000 miles with no issues.
I know there is junk out there, and I suppose we've been lucky. I do however check the air pressure religiously before every trip (including the return trip home) and always ensure the tires are at maximum cold pressure. I'm also careful to not rub against / over curbs and potholes if I can help it. We also cruise at 60mph (ST tires typically max out at 65 mph) so as to not overheat the tires and save fuel.
For the time I've been doing this, I've yet to see a true consensus on which tires are best, and which are the worst.
I don't think there's a true answer to your question, only opinions and war stories.
Good luck!
campingguy is offline   Reply With Quote
Old 08-10-2016, 09:52 PM   #3
I have over 10,000 on my original Westlake. No problem. I think a lot of people who speed and that's one of the reasons you hear bad stories. ST are meant for less than 65 mph, if you use them differently, you can anticipate problems.
jonwisconsin is offline   Reply With Quote
Old 08-10-2016, 10:05 PM   #4
There are only two names that have anything close to a decent reputation.
Salune and Maxxis. Everything else is manufacturerd in any number of un regulated plants in China.
If you have 16 inch wheels and your weights are within specs, go with LT tires.
donniedu is online now   Reply With Quote
Old 08-11-2016, 09:08 AM   #5
Elkhounds's Avatar
We are running the factory Westlakes as well. Got just over 5000 miles on them this year and have another 3500 planned. That said we will be getting either Maxxis, GoodYear 614 or looking at the Salune.
You didn't say what size tire you need. If you are 14 or 15 I would say Maxxis is the way to go. That is what we had on our TT and those were 14's.
As for speed I have seen several of the ST tires rated to 75 mph. Our factory Westlakes are one of them. I like the extra cushion with that but we still set the cruise at 62-63.
2015 F-350 Platinum 6.7 PowerStroke
2017 Columbus 320RS
Andersen Ultimate Aluminum hitch
18,900 miles of RV'ing since May 2014
Elkhounds is offline   Reply With Quote
Old 08-11-2016, 10:10 AM   #6
Iwannacamp's Avatar
I will add...If you are not in a hurry...watch E-bay for Discount Tire Direct. I found(heard on here) about a special. $100 off on tire set. Got a whole set app. $100 cheaper. No tax. No freight. Only had to get mounted $60
Our new 5er 10-26-16
Days camped 2016 8
Old 08-11-2016, 10:14 AM   #7
The most important 4 letters when talking trailer tires:
TPMS
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 08-11-2016, 11:21 AM   #8
Airdale's Avatar
Can you give us a reference as an example of a tire manufacturer that is unregulated and still able to get tires into this country with a DOT certification on its sidewall?
USN - RET - PDRL
DOD - RET - Journeyman Aircraft Mechanic
SSA - RET
Airdale is offline   Reply With Quote
Old 08-11-2016, 11:26 AM   #9
Airdale's Avatar
Steve
Did you have problems with your original tires? If not, why not just use them again and to feel more comfortable increase the load range up one letter, if possible.
USN - RET - PDRL
SSA - RET
Old 08-11-2016, 12:08 PM   #10
Life is great's Avatar
I put Gladiator QR25-TS on mine the beginning of last year and they have worked out great so far. Have several other friends that have ran them for years and always go back.
2012 Rockwood Signature Ultra Lite 8312SS riding on Gladiator rubber.
2004 Ford F350 (Black Beauty) CC, SB, 6sp, 6L work horse.
Camped
2016 - 21 nights
2017 - ??
Life is great is online now   Reply With Quote
tire, tires, trailer, travel, travel trailer
