Old 08-13-2019, 11:00 AM   #1
Trouble finding fuse
Just bought our first Camper. A 2018 Puma 257 RES 5th wheel. When I picked it up everything worked fine but being a truck driver I did a final walk around and hit the retract button for The stabilizers again to assure theyíre up. Now they donít work. Figure I blew a fuse but am having a bit of a problem finding it. Itís the Lippert rear stabilizer that quit working and everything else works so Iím hoping for an easy fix......... also, does anybody know where the TV mount backing is in the bedroom? The stickers was actually on the ceiling
Tracohn is offline   Reply With Quote
Old 08-14-2019, 07:36 PM   #2
You should have a winder to bring the stabilizer jacks up manually. The fuse should be in the power distribution center.
As for the tv bracket, there isnít one. The sticker is there to show where Puma put appropriate structure to mount a television. From your description it appears that your unit was designed for a swing down type mount.
2019 Puma 255RKS 5th Wheel
2013 Ford F-150 w/ max tow
tjwoody is offline   Reply With Quote
Old 08-15-2019, 08:00 AM   #3
Thank You... I will have to check there
fuse
