Old 03-03-2013, 10:45 AM   #1
rpresley's Avatar
TV removal
It may sound dumb but how do I remove the bedroom TV in order to get access to the ports on the back. Not sure how to get it off the mounting bracket. Tried lifting up but was afraid of breaking something.
rpresley is offline   Reply With Quote
Old 03-03-2013, 11:42 AM   #2
Oaklevel's Avatar
Not sure which brand camper you have our 2013 Puma is on two pins so you can also use it on the outside of the trailer. It just lifts up but was stuck the first time..... Also ours is on a swing arm that you have to pull a pin up (It is on the right side) to get it to pull out and tilt it sideways. You have to reach it from the top.....
But in any case on most brackets the TV is held on by 4 screws.....
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 03-03-2013, 12:18 PM   #3
rpresley's Avatar
Thanks it a new Sabre 32RCTS. Its so tight to the wall I can't see behind it. I would suspect there is a way to release it from the mounting plate but I haven't figured it out
Old 03-03-2013, 12:25 PM   #4
rattleNsmoke's Avatar
On my CC, there were two allen head screws that attach the tv mount frame to the wall mount. You'd need a long extension with an allen head socket for removal.
rattleNsmoke is offline   Reply With Quote
Old 03-03-2013, 12:40 PM   #5
rpresley's Avatar
Mission accomplished just took a little more force than I was willing to give. All it needed was a firm push upwards.
Thanks for the suggestions
Old 03-03-2013, 02:05 PM   #6
Good Yob mon......
