Old 09-26-2015, 02:19 AM   #1
Vacuum
Our central vacuum stopped working. It will come on when you wiggle the hose plate but keeps shutting off. I pulled the plate to see if there was a short, but could not fnd anything. Anybody run into this issue?
Frank & Kathy
2015 Columbus 320RS
2012 Chevy Silverado 2500 HD
paluka44 is offline   Reply With Quote
Old 09-26-2015, 07:26 AM   #2
Same problem with ours. Different camper but probably the same vacuum. Vacuum turned on/off a couple of times at dealer and at home. First trip out and the vacuum would not work. Power to the unit was good and so the problem has to be inside the sealed canister. Took the canister back to the dealer and I'm waiting on a replacement.
Steve and Kim
Southern Illinois
2015 Sanibel Traveler 33RS
2011 F350 SRW Crew Cab
si camper is offline   Reply With Quote
Old 09-26-2015, 07:50 PM   #3
We are ours back to the dealer in a few weeks for some other issues and we will have them check out the vacuum unless I find the problem before that.
Frank & Kathy
2015 Columbus 320RS
Old 09-26-2015, 08:21 PM   #4
asquared's Avatar
Haven't had the issue but are the sensors getting good contact?
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-26-2015, 08:39 PM   #5
When I remove the plate from the wall, i don't see any contacts. They seem to be inside the plastic housing where the plastic door is, to open it for the hose.
Frank & Kathy
2015 Columbus 320RS
