Old 02-25-2013, 05:07 PM   #1
Vacuum Problem
Help! our 2013 365RL vacuum will not shut off when you remove the hose. I had to remove the step and unplug it. Has anyone else had this problem?
OurPlace is offline   Reply With Quote
Old 02-25-2013, 06:25 PM   #2
tncruiser's Avatar
have you tried plugging it back in.it turns off and on by a relay activated when insert the hose ,on most models when the unit is first plugged in the motor will run for about 2 seconds. i assume its under warranty and i would bet the dealer replaces the whole unit
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 02-25-2013, 07:49 PM   #3
Yes I tried that and disconnected the wires where the hose plug plugs in...........yes its still under warranty. I just thought there might be a simple fix.
Thanks for the reply
Old 02-25-2013, 08:05 PM   #4
Dave_Monica's Avatar
I found a troubleshooting guide on the Dirt Devil site on their RV cantral vac unit. Here's the link... Dirt Devil® RV Central Vacuum Troubleshooting
Dave
Old 02-25-2013, 08:36 PM   #5
amxpress's Avatar
I know this might sound silly, but is the flap snapped shut all of the way down? Sometimes, ours is a little tight when shutting.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 02-26-2013, 01:04 AM   #6
SYE
SYE's Avatar
The same thing happened on my Columbus the first time that I used it, I had to pull the fuse. I came back out 2 days later and then it worked fine. I took it to the dealer and they could not find anything wrong with it and since then, it has never happened again. It will probably do it the first trip after warranty expires.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 03-10-2013, 11:15 AM   #7
Thanks for all the help, sorry I havent answered sooner I'm working 7-13's so soon as i get some me time I'll try the fixes.
Donnie
Old 03-16-2013, 08:37 PM   #8
amxpress's Avatar
This happened to me today. Here's what I found. I lifted the cover to suck up my sweepings. When I closed it, the vacuum stayed running. Upon investigating, I found the round cap covering the hole has two tabs or ears located at the top. These tabs slide into a slot inside the outer square cover. It seems the tabs came out of the slots so when the cover was closed, it failed to make connection and didn't shut off the motor. I reinstalled the cap tabs into the slots and fixed it. I'll get pictures when I return home. We're camping so I'm kinda busy. Fishing, hot tub, napping, eating, etc.
Prodigy
