Old 09-14-2016, 09:26 AM   #11
NMWildcat's Avatar
Lol.... This thread is funny. And yep, mine has an o-ring.....
Scott and Liz - Southern NM
Old 09-14-2016, 11:42 AM   #12
Originally Posted by Davidceder View Post
Maybe I should have said "If the cover should have an O-Ring" I am not an English major.....
OK, went out and took pics of mine. Yes, it has an o-ring on the cap and an o-ring where it mounts to the drain pipe. This is the end that attaches to the drain pipe from RV..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 09-14-2016, 11:44 AM   #13
This is cap that covers the valve.. Go get an o-ring or you will not be able to balance your grey tanks without a drip..
2016 Siverback 33IK
Old 09-14-2016, 11:50 AM   #14
ALL have a Seal,some have a O-ring others have a Quad-Ring,regardless ALL have a Seal! Both types are round and Black! DNA is the Only way to tell if it is Yours! Youroo!!
Old 09-14-2016, 12:14 PM   #15
Thank you
My skin is thick enough!
Thanks everybody. OH by the way, no need to respond to my thank you. I don't think I could take it.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-14-2016, 01:27 PM   #16
NMWildcat's Avatar
They have a pack of those orings at Walmart, and an extra cap for cheap
Old 09-15-2016, 10:38 PM   #17
OK, so go to the store and find the connector just like yours and see if there is an O ring in it (all my caps have rings of some sort). If it does and yours doesn't, try the one you picked up off the ground (clean it first) and if it fits you are all set. You can also buy another one at Camping World if yours leaks.
ProfChuck is offline   Reply With Quote
Old 09-15-2016, 11:06 PM   #18
So much common sense I can't take it.
Valterra is sending me 2 seals.
Old 09-15-2016, 11:22 PM   #19
The other thing you should watch is that the plastic hose sometimes gets leaks in it. These things don't last forever, so make sure your hoses are good and the connections from the connectors to the hose itself is tight and good. The better the hose, the more it costs, but it is worth it. The cheap ones don't last very long. I just had a connector give up the ghost after 10 years (one of the prongs broke off) and with a spare in the box, it was a no problem fix. Enjoy your camping.
Old 09-17-2016, 11:19 AM   #20
tugboat369's Avatar
Looked again and the cheap replacement cap i keep as a spare has no seal the one on the RV has one.
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
tugboat369 is offline   Reply With Quote
