09-13-2016, 06:58 PM
Valterra Twist on Waste Valve
While dumping this morning I found a snapped O-Ring under my rig. Not sure where it came form or if it is from my rig. I wonder if anyone can please tell me if the cover of the Valterra twist on valve that I have at the end of my sewer line has an O-Ring about 2.5-3 inches. If the link below works it will identify which valve I am speaking of.
Twist On Valve Archives - Valterra.com | Valterra.com
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
09-13-2016, 07:13 PM
Why don't you just look to see?
09-13-2016, 07:53 PM
Well
OK, I looked and don't have an O-Ring. Now can you tell me if the one I found under the rig came off the cap from where it belongs or is it just a an O-Ring from someone else?
What am I missing? That's not an answer........
09-13-2016, 08:12 PM
Clarification
Maybe I should have said "If the cover should have an O-Ring" I am not an English major.....
09-13-2016, 08:15 PM
Mine does not have a o ring on the cap.I don't even see a place where it would go.
2011 Ram Mega Cab 3500 Larimie dually
2016 Chaparral 370FL
09-13-2016, 08:24 PM
Crookedread
On quiet days when I have nothing to do, I take my bag of cut o-rings and scatter them around the park. It's so much fun! Sorry, couldn't help myself!!
Seriously, how could anyone tell you if it came off of another rig?
Personally, I would assume that it came off another rig as most o-rings are captured. Then I would watch for any drips under my trailer for a while, especially when the tanks were at or near capacity.
Crookedread
2016 Duramax
2011 Stealth 2312
09-13-2016, 08:28 PM
HELP!!!!!!!
Why is this so difficult? I am only asking for someone who has this valve to look inside their cover to see if theirs has an O-Ring. If not, OK, I am good. If yes, than mine is missing the O-Ring regardless if it was the one I found or not.
09-13-2016, 08:39 PM
Damn David chill.I answered your question.I SAID MINE DOES NOT HAVE A O RING ON IT.There I did it again
09-13-2016, 08:45 PM
The sewer hose should have an "O" ring in its connector. Did you dump?
09-14-2016, 08:18 AM
My cap has ho O ring I just looked
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
09-14-2016, 08:26 AM
Lol.... This thread is funny. And yep, mine has an o-ring.....
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
09-14-2016, 10:42 AM
OK, went out and took pics of mine. Yes, it has an o-ring on the cap and an o-ring where it mounts to the drain pipe. This is the end that attaches to the drain pipe from RV..
09-14-2016, 10:44 AM
This is cap that covers the valve.. Go get an o-ring or you will not be able to balance your grey tanks without a drip..
09-14-2016, 10:50 AM
ALL have a Seal,some have a O-ring others have a Quad-Ring,regardless ALL have a Seal! Both types are round and Black! DNA is the Only way to tell if it is Yours! Youroo!!
09-14-2016, 11:14 AM
Thank you
My skin is thick enough!
Thanks everybody. OH by the way, no need to respond to my thank you. I don't think I could take it.
09-14-2016, 12:27 PM
They have a pack of those orings at Walmart, and an extra cap for cheap
09-15-2016, 09:38 PM
OK, so go to the store and find the connector just like yours and see if there is an O ring in it (all my caps have rings of some sort). If it does and yours doesn't, try the one you picked up off the ground (clean it first) and if it fits you are all set. You can also buy another one at Camping World if yours leaks.
09-15-2016, 10:06 PM
So much common sense I can't take it.
Valterra is sending me 2 seals.
09-15-2016, 10:22 PM
The other thing you should watch is that the plastic hose sometimes gets leaks in it. These things don't last forever, so make sure your hoses are good and the connections from the connectors to the hose itself is tight and good. The better the hose, the more it costs, but it is worth it. The cheap ones don't last very long. I just had a connector give up the ghost after 10 years (one of the prongs broke off) and with a spare in the box, it was a no problem fix. Enjoy your camping.
09-17-2016, 10:19 AM
Looked again and the cheap replacement cap i keep as a spare has no seal the one on the RV has one.
2014 Columbus 320RS
