Old 02-17-2019, 08:26 PM   #1
Want to add 12V recepticle
I am thinking about adding a 12V receptacle above my wife's side of the bed for her C-Pap. I want to place this close to her overhead reading lamp so I can tap off those wires. Currently we run a really long cable out the bedroom over to the charging station, about 10 feet.
Do you guys think I need a separate fuse for the receptacle or will the fuse that is already in the circuit for the reading lights work. All the lights in the bedroom are usually out when she turns it on and they are all LEDs.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 02-18-2019, 10:41 AM   #2
Head Rambler
It all depends on what size fuse is in the existing circuit, but I suspect that it is probably a 15 amp which would be fine.
I assume that the light is locally switched so getting power when it's off isn't an issue.
Gotta go campin!
Old 02-18-2019, 10:56 AM   #3
the lights are 12 volt the outlets are 110. Need to come off an existing recept and hope that the circuit it is on does not get overloaded with other things.
Kimber45 is offline   Reply With Quote
Old 02-18-2019, 11:02 AM   #4
Trailer Park Supervisor
NJKris's Avatar
Most likely everything is off when she is sleeping, so little chance of overloading any circuits.
NJKris is offline   Reply With Quote
Old 02-18-2019, 11:23 AM   #5
Thanks for the replies. The lights are indeed locally switched and are on a 15 amp fuse.
Old 02-18-2019, 11:37 AM   #6
there is a big difference between a 12 volt light on a 15 amp fuse and a 110 volt outlet on a 15 amp breaker. its my understanding that cpap machines are 110 volt?
Old 02-18-2019, 11:44 AM   #7
It is 12 V into the CPAP
The power brick on the C-PAP takes 110V in but puts out 12V DC to the unit. Been running it for years on a 12V jury rigged setup. Just want to do something cleaner.
Old 02-18-2019, 12:26 PM   #8
PPST Wannabe
kenandterry's Avatar
I’m confused......it doesn’t take much.
Does your CPAP machine need 12 volt DC OR 110 volt AC to operate?
I’m not asking if it produces 12 volt for whatever, but rather what does the CPAP
machine REQUIRE to operate.
I’m also confused by the term “power brick”.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 02-18-2019, 01:05 PM   #9
cavie's Avatar
Proably won't be any hot wire at the light with the switch off.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 02-18-2019, 01:55 PM   #10
Are you sure about the voltage? My CPAP uses 110 volt vac to power the “brick” which converts the 110 to 12 vac.
I purchased a 12 vdc to 12 vac “brick” for use in my trailer.
I haven’t tried it out yet but looking to power the same way you are. Except for 2 bricks. I’d be interested in knowing how that works for you.
After posting I had a second thought and looked at the input / output of my “bricks”. They are marked.: original = “input 110 vac with an output of 24 vac 3.5 amps. New brick = “input 12 vdc 13.5 amps with an output of 24 vac. No output amps mentioned on the label. Sorry for any confusion I might have caused.
Clyde M is offline   Reply With Quote
