Old 08-30-2012, 04:19 PM   #11
TURBS's Avatar
Originally Posted by Oakman
In the spring after I have flushed the antifreeze out the lines thoroughly, I turn the water off, remove the filter housing and empty it, put in a fresh water filter for the season, and then turn the water back on.
Yep !
Old 08-30-2012, 05:44 PM   #12
ret2006's Avatar
I will take my filter out and put the canister back on. I didn't want to waste pink stuff so I made a by-pass using two of the water heater bypass kits valves.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 08-30-2012, 07:38 PM   #13
Originally Posted by youroo View Post
Remove the canister,remove the filter element,place a plastic soda(pop) bottle with cap on inside where the element was,this does (2) things, displaces anti-freeze that will be pumped into the cannister,and allows for expansion from freezing. Cost-O$ Youroo!!
Thanks, I'll try that.
Old 08-30-2012, 07:54 PM   #14
j2detroit's Avatar
We have an 06 Cherokee that also came with one of those very nice double inline filters ... what a pain after the first season while winterizing I cut the line and added a new chuck of hose in and got rid of these filters and just buy a 20 dollar inline filter each season
j2detroit is offline   Reply With Quote
Old 09-02-2012, 10:36 AM   #15
Wanna Be Camper
SaskCampers's Avatar
Don't worry about the RV antifreeze freezing. It will at worst turn to a slush. We live where it can go as low as -40 and I have yet to have an issue. THe only thing I would say is when you take the filter canister off to remove the filter, dry the threads on the housing and the canister with a paper towel prior to reinstalling the housing. The water in the threads can crack things if it does not get time to evaporate on it's own before a freeze (I have had fittings on a pressure washer crack before).
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-02-2012, 11:06 AM   #16
mike54's Avatar
last winter I took out the filter out pumped the antifreeze thru the system dumped the filter canister down the toilet screwed it back on. This year I won't have the mess from the water filter I had it removed.
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 09-02-2012, 11:09 AM   #17
Oakman's Avatar
A heads up when you remove the water filter canister. There is a rubber O ring in the top of the canister, donít loose it when you empty the canister or you will have water leaks until you find a replacement.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 09-05-2012, 01:07 AM   #18
I thought about doing this myself, but it seemed to me that you can by a lot of antifreeze at$2/Gal (typ sale price) for the cost of the bypass. That said, I will probably still do what you did on my own rig
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 09-05-2012, 06:05 AM   #19
TURBS's Avatar
Where do yo u buy it for 2 a gallon ?
Old 09-05-2012, 07:28 AM   #20
Menards 1.99 /gal on sale in Michigan
Cathy & Jeff
Midland, Michigan
