Old 08-30-2012, 12:19 PM   #1
Water Filter and Winterizing
On my new Sabre 34TBOK which is being delivered tomorrow it has a water filter which my 2008 Crossroads Cruiser did not have. My dealer told me in winter to remove the filter and install a line in place and then do the winterizing. Does anybody else do this? They told me that if I fill the filter with RV Antifreeze I run the risk of cracking the housing. What are your experiences?
2013 Ram 2500 SLT 4 x 4 c/w 5.7L & 4.10 - 6spd Auto
2013 Palomino Sabre 34TBOK-6
2014 GMC Sierra SLE 4 x 4 c/w 5.3L - 6 spd Auto
2011 Crestliner Superhawk c/w 115HP Mercury
2012 Honda CBR250
iceman31 is offline   Reply With Quote
Old 08-30-2012, 12:21 PM   #2
TURBS's Avatar
On my sabre I remove filter and drain water then fill canister back up with antifreeze since I installed a winterization kit that uses the pump to draw in antifreeze from the jug.
Old 08-30-2012, 12:40 PM   #3
Oakman's Avatar
I don't have a Sabre, but on my previous Wildcats I removed the filter and then when I pumped antifreeze back into the lines I allowed the canister to fill with antifreeze. I've been doing this for 8 years. This is the procedure I will use on my Silverback this year too. I have no clue why the dealer would tell you the canister could crack if it is filled with antifreeze, unless you live in a climate where antifreeze will actually freeze. Like I said, I don't have a Sabre but it sounds to me like you have a dealer that doesn't know his butt from a hole in the ground.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 08-30-2012, 12:42 PM   #4
TURBS's Avatar
Originally Posted by Oakman
I don't have a Sabre, but on my previous Wildcats I removed the filter and then when I pumped antifreeze back into the lines I allowed the canister to fill with antifreeze. I've been doing this for 8 years. This is the procedure I will use on my Silverback this year too. I have no clue why the dealer would tell you the canister could crack if it is filled with antifreeze. Like I said, I don't have a Sabre but it sounds to me like you have a dealer that doesn't know his butt from a hole in the ground.
X2
Old 08-30-2012, 12:58 PM   #5
Steve Jackson
sideout1961's Avatar
Seeing as we are talking about winterizing, what procedure do you all use for the freshwater tank? I haven't used my tank since I bought the trailer in March. I have only camped in full hookup sites. Which leads me to another question is there something I should be doing to this tank if I don't use it?
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 08-30-2012, 01:30 PM   #6
TURBS's Avatar
Just drain it unless there's no water in it then do nothing.
Verify that it's truly empty by leaving draIn valve open on next outing
Old 08-30-2012, 03:29 PM   #7
This is our first camper with an on board water filter. We don't use it (no filter in the canister) because we have an exterior inline filter. So then you just leave the antifreeze in the canister all winter? I assume the antifreeze will get flushed out of the canister in the spring when you hook up the water again.
Old 08-30-2012, 03:45 PM   #8
Road-King's Avatar
Just like you we do not use our on board filter ether. I am planning on by passing the filter housing when I winterize and never look back. It is a PITA to get to on our TT.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 08-30-2012, 03:47 PM   #9
Remove the canister,remove the filter element,place a plastic soda(pop) bottle with cap on inside where the element was,this does (2) things, displaces anti-freeze that will be pumped into the cannister,and allows for expansion from freezing. Cost-O$ Youroo!!
Old 08-30-2012, 04:09 PM   #10
Oakman's Avatar
In the spring after I have flushed the antifreeze out the lines thoroughly, I turn the water off, remove the filter housing and empty it, put in a fresh water filter for the season, and then turn the water back on.
Bob and Joyce
ATU Local 788
Old 08-30-2012, 04:19 PM   #11
TURBS's Avatar
Yep !
Old 08-30-2012, 05:44 PM   #12
ret2006's Avatar
I will take my filter out and put the canister back on. I didn't want to waste pink stuff so I made a by-pass using two of the water heater bypass kits valves.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 08-30-2012, 07:38 PM   #13
Thanks, I'll try that.
Old 08-30-2012, 07:54 PM   #14
j2detroit's Avatar
We have an 06 Cherokee that also came with one of those very nice double inline filters ... what a pain after the first season while winterizing I cut the line and added a new chuck of hose in and got rid of these filters and just buy a 20 dollar inline filter each season
j2detroit is offline   Reply With Quote
Old 09-02-2012, 10:36 AM   #15
Wanna Be Camper
SaskCampers's Avatar
Don't worry about the RV antifreeze freezing. It will at worst turn to a slush. We live where it can go as low as -40 and I have yet to have an issue. THe only thing I would say is when you take the filter canister off to remove the filter, dry the threads on the housing and the canister with a paper towel prior to reinstalling the housing. The water in the threads can crack things if it does not get time to evaporate on it's own before a freeze (I have had fittings on a pressure washer crack before).
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 09-02-2012, 11:06 AM   #16
mike54's Avatar
last winter I took out the filter out pumped the antifreeze thru the system dumped the filter canister down the toilet screwed it back on. This year I won't have the mess from the water filter I had it removed.
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 09-02-2012, 11:09 AM   #17
Oakman's Avatar
A heads up when you remove the water filter canister. There is a rubber O ring in the top of the canister, dont loose it when you empty the canister or you will have water leaks until you find a replacement.
Bob and Joyce
ATU Local 788
Old 09-05-2012, 01:07 AM   #18
I thought about doing this myself, but it seemed to me that you can by a lot of antifreeze at$2/Gal (typ sale price) for the cost of the bypass. That said, I will probably still do what you did on my own rig
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 09-05-2012, 06:05 AM   #19
TURBS's Avatar
Where do yo u buy it for 2 a gallon ?
Old 09-05-2012, 07:28 AM   #20
Menards 1.99 /gal on sale in Michigan
Cathy & Jeff
Midland, Michigan
