Old 03-05-2017, 10:44 AM   #1
Puma 2015's Avatar
Water heater
I have a 2015 puma 31', I have a propane switch inside but not an electric one. What is the switch for that is in the lower left of the water heater outside
Puma 2015 is offline   Reply With Quote
Old 03-05-2017, 10:48 AM   #2
larrys2112's Avatar
That is the electric switch.
2016 Rockwood Windjammer 3008W Diamond Package
2016 Toyota Tundra Double Cab 5.7L SR5 4x4
larrys2112 is offline   Reply With Quote
Old 03-05-2017, 10:50 AM   #3
Puma 2015's Avatar
Why didn't they put it inside
Old 03-05-2017, 11:00 AM   #4
wmtire's Avatar
This link may help explain the operation of.
Suburban's electric switch and much more
Suburban does make a model with the electric switch inside. However, if you inadvertently EVER turn it on without water in the tank, then you get to replace your now burned up electric heating element.
Having the electric switch on the tank itself, let's you also verify there is water in the tank BEFORE turning on the electric element.
It's explained in the link.
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
Old 03-05-2017, 11:11 AM   #5
Puma 2015's Avatar
Thank you,very helpful
heater, water, water heater
