Lets start with checking your bypass valves (as Avid said). A part of dewinterizing is making sure the bypass valves are turned for normal operations. Many HW systems have three valves -two for the intake and outtake lines and one valve on a line between the two. Make sure that third valve connecting the others is closed. If its opened, the hot water mixes with the cold.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
