Old 06-15-2013, 08:01 AM   #1
Water heater
Camping this weekend issue with hot water , can you adjust temperature , water isn't that hot and heater won't turn on , was workin fine.
walnuts0806 is offline   Reply With Quote
Old 06-15-2013, 08:22 AM   #2
TURBS's Avatar
No you can not adjust it.
Are the by pass valves turned correctly ?
Are you using gas or electric side of wh ?
TURBS
Old 06-15-2013, 08:36 AM   #3
Using gas just doesn't seem hot ,valves are open all the way, it did fire up after maybe just wasn't calling for heater yet?
Old 06-15-2013, 08:46 AM   #4
Denver, CO
garbonz's Avatar
Are the by pass valves turned correctly ? X2
either that or the thermostat is bad or going bad.
2017 Fuse 23T
Old 06-15-2013, 09:09 AM   #5
dfskinner's Avatar
if you had your trailer winterized and this is the first trip out, the values are closed going to the WH tank....... check the valves (X3)........
you can also turn your gas off and switch your WH over to electric to make sure it's not the gas you are having problems with....... search on "water heater" and "electric" on the forum; really good section about "Water Heaters" here; it's locked, but it has some really good info....
Thanks,
Dennis
Day's Camped 2014 - 35 so far
2012 Rockwood Windjammer 2809W
2004 Dodge Ram 5.7L 4X4 Quad
dfskinner is offline   Reply With Quote
Old 06-15-2013, 07:37 PM   #6
Thanks the winterized valve was turned off thanks for the help!!
Old 06-16-2013, 10:09 AM   #7
TURBS's Avatar
Good deal!
Thanks for the follow up
