Old 08-16-2017, 04:36 PM   #1
Water heater drain
Is it necessary to train the water heater after each use?
wipfr is offline   Reply With Quote
Old 08-16-2017, 05:35 PM   #2
SYE
SYE's Avatar
No, I fill it in April and drain it in November
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 08-16-2017, 05:39 PM   #3
Oakman's Avatar
X2.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 08-16-2017, 05:43 PM   #4
markb5900's Avatar
If the trailer sits for 3 or 4 weeks, I go ahead and drain the tank and the FW tank and refill it.
Takes 20 minutes and you don't get the "smelly" water as my grandson says when you first turn on the faucets.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 08-16-2017, 05:44 PM   #5
How do I drain it? There is no valve by the water heater.
Old 08-16-2017, 05:47 PM   #6
markb5900's Avatar
On the bottom, there is what looks like a BIG nut. Don't remember the exact size, but thinking 1 1/8".
That is the anode rod. You unscrew that and the water will start pouring out.
I use a socket on an extension to get it out.
When putting it back BE CAREFUL not to cross thread it. Takes some nimble fingers to get it started threaded back in
Mark B
2017 GMC 3/4 Ton TV
Old 08-16-2017, 05:49 PM   #7
I did see that rod above the wheel. Didn't know that's what it was for. Thanks.
Old 08-16-2017, 07:06 PM   #8
Flybob's Avatar
socket size is 1 1/16".
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-16-2017, 07:08 PM   #9
Be sure to relieve the pressure in the system before removing it. if you don't the plug will shoot out and spray you with water. Don't ask me how I know.
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 08-23-2017, 12:09 PM   #10
BuckeyeChuck's Avatar
You may want to let it cool down before draining it.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
drain, heater, water, water heater
