Old 06-26-2016, 08:52 AM   #1
Water leak in 320RS
Hey folks, just wondering if anyone has had a water leak in the bathroom/bedroom area? I just pulled the vanity out and am in the middle of tearing out the floor in the bathroom and part of the bedroom. The main rotted wood is right above the duct in both rooms. I cannot see any water on any of the water lines or drains. That leads me to believe that it is coming from the roof and down the wall and soaking the floor. Has anyone had this problem. The other question is, there is a vent just in front of the skylight. ON the bottom of the vent is a plug in the garage area. Does anyone know what this is for?
Thanks for any help
ID:	112240   Click image for larger version
Dave and Kim
Charlie and Ripken (4 Leggers)
2012 GMC Sierra Denali 2500 6.6L Diesel
2013 Columbus 320RS
Maryland
Times camping in 2013 - 5
Sporoo is offline   Reply With Quote
Old 06-26-2016, 04:03 PM   #2
Rmk2001800's Avatar
Call the factory they might be able to help with seeing this issue in the pass.
Rmk2001800 is offline   Reply With Quote
Old 06-28-2016, 09:25 PM   #3
TURBS's Avatar
My 2015 was leaking from the very front corner of the bedroom slide leaving the floor wet up by the head of the bed.
Sent from my SCH-R530U using Tapatalk
Old 07-03-2016, 07:23 AM   #4
tugboat369's Avatar
Check the bottom corner of the shower chanel
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
tugboat369 is offline   Reply With Quote
Old 07-21-2016, 04:24 PM   #5
Faucet?
We had a water leak in our 320RS that neither we nor the dealer could find, and it was driving us crazy. All we could see was a puddle about 12 inches wide in the cargo bay and sometimes water on the floor inside the vanity. But it never leaked when we turned on the faucets and looked. Judging by the fact that you said you had rotted wood under the vanity, you may have a leak in the same place we did. It went on sporadically for two years. Eventually, I just took a chance and removed the water supply tubes from the vanity's faucet, wrapped the threads in Teflon plumbers tape and screwed it all back together. Hasn't leaked a drop since. Don't know why the dealer didn't think of this, but they didn't. I don't know if that'll help, but when you put your vanity back in, it might be a good idea to use that Teflon tape on the faucet connections.
Dennis and Kathy
And Aggie the Gordon setter
2015 Columbus 320RS
2016 Ram 3500 diesel
Employment was great, but retirement is better
dbuster is offline   Reply With Quote
Old 03-18-2017, 12:13 PM   #6
Our 2014 320RS leaks from the shower doors that don't seal. We put a shower curtain and rod to fix the problem
Flatop is offline   Reply With Quote
Old 03-21-2017, 08:07 PM   #7
amxpress's Avatar
The tube you are referring to that runs from the roof to the basement allows you to run wiring for solar panels or satellite antenna that you might mount on the roof in the future.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 05-18-2017, 07:55 PM   #8
I have a 2015 320rs...had small puddle in storage bay, under shower area. Turned out it was an anti-syphon valve. In the wall behind shower hot-cold knows. Just a cheap valve. I removed it.plugged line. No more leak.
mitchwright is offline   Reply With Quote
320rs, leak, water, water leak
