Old 07-15-2018, 12:11 PM   #1
Water leak when heavy rain.
We purchased our Columbus 340RKC in March and love it. We are currently on the 5th leg of our RV adventure and have survived a couple of problems. The first was a leak from behind the shower wall that ran into the basement area and leaked pretty badly. It was finally repaired at a dealer in Ocala, Fl. when they located the cold water line had been pierced by a screw during assembly. The second problem occurred last month in Tennessee when the converter went bad and killed the batteries and all 12volt to the unit which is needed to start the AC units. We came home to a 100* sweat box. They ordered the part and fixed it the next day which cost us a night in motel because it was too hot to sleep in it.
Now we have a new issue. When it rains it leaks down the inside of the back wall behind the range area. The only thing on the back wall in the drivers side corner is the rear clearance light. I have placed a bead of silicone across the light and it seems to have prevented almost all of the leak unless it pours. Do you think I should remove the light and reseal and recaulk the light before re-installing it? The dealer will only do it for cash and not warranty work. Thanks for your help everyone.
navygrandparents is offline   Reply With Quote
Old 07-15-2018, 12:20 PM   #2
I would remove it clean all the old caulk off, recaulk and reinstall.
Gonefishing1 is offline   Reply With Quote
Old 07-15-2018, 12:32 PM   #3
On repairs like this I'd rather save the cash and do it myself so I know it's done right. A tube of good "RV Sealer" is $10-$12.
On my previous TT I had the front window re-sealed twice by the Dealer under warranty. In the end I had to re-do it myself and only then did the leak stop.
Nice thing about this day and age, even if one is totally unfamiliar with what needs to be done a quick "Google" for a How To video will yield several videos that will walk you through the process of repairing just about anything on an RV that doesn't require tools other than what are commonly in one's toolbox.
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-15-2018, 12:36 PM   #4
Flybob's Avatar
I would remove the light and seal the hole for the power wire and the screw holes then put the light back.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-15-2018, 01:12 PM   #5
water leak
You are all so right. I initially did a quick seal around the top of the light like the factory does on almost anything outside that needs to be sealed and it helped greatly. I agree with removing the screws and lens, recaulk the mount holes and reinstall and then recaulk around the light base. And like you said be sure to buy a good silicone caulk and not some cheap stuff.
Old 07-16-2018, 10:40 PM   #6
JJaxon's Avatar
If one light needs it they all could use it. Buy a good rv sealer, not household caulk or silicone, plan a few hours and do all the upper and lower marker lights and anything that penetrates by removing, clean, seal the holes and reinstall. You won't regret it, and might be surprised by what you find as you do them. Many people put it off for a few years then find noticable rot or damage, delam, and realize it could have been prevented. I just finished a huge repair from water getting in a single bolt hole on the front of my hybrid. $10 tube of sealer is cheaper than any future repair.
John
2017 Ram 2500 CC 4X4 Cummins 6.7l
2006 Starcraft Toy Hauler Hybrid 25TB
JJaxon is offline   Reply With Quote
Old 07-16-2018, 11:13 PM   #7
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I personally prefer Proflex RV, either white or clear. The problem with silicone is that it's not as durable and nothing but silicone itself will properly stick to it.
https://www.amazon.com/Geocel-28100V.../dp/B001FC98X2
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 07-17-2018, 03:51 AM   #8
DouglasReid's Avatar
I only use Lexel. It drys totally clear and is VERY sticky (never fails to seal).
It will stick to anything and additionally, if you want, it is paintable.
Not cheap but GOOD Stuff!
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 07-19-2018, 04:31 AM   #9
An Amish guy, that worked at the factory doing repair work, and NOW has his own company doing repairs to Only Cedar Creek RVs told me he only uses GeoCel MHRV 2300 clear caulk, its flexible and stands up to the sun.....and NOT to use silicone caulk. He gave me a tube, and I have also ordered a few on the internet. It isn't cheap.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
Retired Dept of Navy Flt Test Engineer
Splashes3 is offline   Reply With Quote
Old 07-19-2018, 09:38 AM   #10
JJaxon's Avatar
It is much cheaper than paying for extensive repairs due to poor quality build, andlack of routine maintenance. If it were $25 a tube id take a case over having my investment destroyed by water.
John
leak, water, water leak
