Old 01-05-2013, 05:18 PM   #1
Water pressure ?
Does anybody know what water pressure we are suppose to use for city water hooked up to our trailers.
We have a 2013 295rl, and I am going to order an adjustable water pressure guage instead of using the factory non adjustable presure guage.
Thanks.
Jon
2001 Dodge 3500 4x4 dually
Exhaust brake, 4" SS exhaust
DDP injectors, Edge chip
B&W hitch
2013 Columbus Palomino 295RL
Jon_Celia is offline   Reply With Quote
Old 01-05-2013, 05:23 PM   #2
H2oski
I think my factory set regulator is set at 45 psi. Hope this helps.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 01-07-2013, 11:43 AM   #3
Fulltime family RVer
I set my adjustable (Watts regulator from rvwaterfilterstore.com) to 40-45-ish.
ependydad is online now   Reply With Quote
Old 01-07-2013, 11:50 AM   #4
DnD
DnD's Avatar
I set my adjustable regulator at 40-45 as well. This was what my PDI tech recommended and confirmed by a few friends who are life time RV'ers.
Dan n Dione
TV: 2012 Ram 3500 Laramie CC LB 4x4 DRW
RV: 2013 Crusader 325RES Touring Edition
Days Camped: 2012 (3) 2013 (22)
Next Trip: Mission Bay, CA 6/6 - 6/9
DnD is offline   Reply With Quote
Old 01-07-2013, 12:32 PM   #5
I am going to order a watts adjustable regulator also and wanted to make sure I get the right one, plus I wanted to make sure I did not put too much water pressure on the system and break the pvc pipes in the trailer.
Thank you.
Jon
B&W hitch
Old 01-07-2013, 12:36 PM   #6
3 Happy Campers's Avatar
All new RVs come with PEX plumbing.
PEX tubing is rated up to 150 PSI.
However the factory facets & bypass valves are not rated for that much.
Your only as strong as the weakest link!
The standard recommendation of 40-45 PSI comes from the older gray tubing you find in older RVs & mobile homes.
The gray stuff had a max rating of 45 PSI.
I replaced all my factory facets with residential ones from Lowes.
I keep my regulator set to 55-60 psi & have had no issues.
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 01-07-2013, 12:42 PM   #7
You can tell what kind of tubing you have by the color.
If you see red & blue tubing you have PEX.
Red being for hot & blue for the cold supply.
They stopped using the gray 10+/- yrs ago after a waive of law suites in the mobile home industry.
Perkasie, PA
2010 Sierra 356RL
Old 01-07-2013, 01:26 PM   #8
Herk7769's Avatar
I bought this one and don't use it any more. It was expensive and now does not work due to calcium deposits from the well water used at most campgrounds.
I find the cheapo fixed one works as good and when the pressure drop from crud becomes noticeable, I toss it and get a new one.
HAM CALLSIGN - KC3FFW
Old 01-07-2013, 01:37 PM   #9
TURBS's Avatar
Have you soaked it in lime away?
Old 01-07-2013, 01:43 PM   #10
jimh's Avatar
or vinegar?
jimh is offline   Reply With Quote
Old 01-07-2013, 02:04 PM   #11
I soak mine (forget the make/model) in CLR at least once a year & it looks/works like new.
Perkasie, PA
2010 Sierra 356RL
Old 01-07-2013, 04:19 PM   #12
Herk7769's Avatar
All good ideas. Maybe one day when I am camping sitting under the awning; wondering what I can do besides have another Margareta.
Old 01-07-2013, 04:23 PM   #13
lgray's Avatar
Water pressure
Just went through the same thing. Purchased this from Camping World $13.00 rated at 50-55 PSI and 15-20% more flow. Research suggested that the new rigs can certainly handle this and that it is not just about PSI, but flow.
Hi Flow Water Regulator - Lead Free - Valterra A01-1122VP - Faucets & Inlets - Camping World
Used it now for three trips, much better showers and kitchen pressure.
lgray is offline   Reply With Quote
Old 01-07-2013, 04:26 PM   #14
Herk7769's Avatar
I see there is one with a gauge too.
In-Line Water Regulator Gauge Combo - Lead Free - Valterra A01-1124VP - Faucets & Inlets - Camping World
Old 01-07-2013, 04:32 PM   #15
lgray's Avatar
The model with the guage is a little lower in PSI and flow at 40-50 PSI.
Old 01-07-2013, 06:08 PM   #16
rattleNsmoke's Avatar
40psi is adequate for most trailers. What happens is the flow gets choked down at the spray head. Take the restrictor out of your faucets and voila! improved pressure.
rattleNsmoke is offline   Reply With Quote
