Originally Posted by Don and Elaine
Has anyone had issues wiith low water pressure in their Columbus' and what is the pressure set at on the intake regulator? I removed the Shower head and took out the water restrictor and drilled out the holes to a larger size only to have a slight increase in water presssure at the shower head. I then removed the restricter and stll very low output on the shower head so I can only deduce that the intake pressure must be low...any ideas?
get a watts regulator from the rvwaterfilterstore and set it to 60 psi. The camping world regulators are flow restriction type and actually reduce the flow. The watts do not.
You have it set up very well, although I would suggest that if you have it set at 45 like may be indicated in the picture, that you move it up to the 60-65 psi range. If the park has it, you will enjoy that much more performance out of your water system. Obviously, if you are too concerned about pressure in the RV, you may choose to leave it at a lower pressure. Your plumbing is rated at 125 psi, so half that should not be an issue. Of course, you may have it already set higher and the pressure at the park is only 45. Anyway, you are good.
