Old 04-20-2013, 08:04 PM   #1
2013 Columbus's Avatar
Water pump
I have a Columbus 320RS
I need to check the water pump. Dose anyone know where the pump is located?
2013 Columbus is offline   Reply With Quote
Old 04-20-2013, 08:24 PM   #2
Inside the driver's side compartment right behind the various hose attachments. You have to remove the panel held on by screws.
mmunn is offline   Reply With Quote
Old 04-20-2013, 09:31 PM   #3
The pump will be behind the panel that is in the center of the back of the compartment. The pump also has a 3 amp DC fuse in that compartment, if you are having problems, check it.
Husker Land is offline   Reply With Quote
Old 04-21-2013, 06:41 PM   #4
I found it, thanks.
Had to prime it to get it to work. Now it is working great.
Thanks for your help!!!
