Originally Posted by Great Horned Owl
In my Palomino Puma 253-FBS I have been unable to locate the water pump. I can only hear out of one ear, so I have trouble trying to localize the direction of the sound.
I have no immediate need to access the pump, but past experience tells me that I will eventually need to get to it.
Joel
I also do not have or know your model, but my onboard water punp in our 2012 Silverback is located in the water servicing compartment (left side) behaid a folding panel.
And Yes you probably will have to access it at some future time. I posted sometime ago that I had a small water leak in the compartment where the pump is and couldn't locate.
I finally found that the pump has a round plastic cover that holds a filter element and the cover had loosened slightly and was leaking just enought to form a small puddle on the compartment floor.
The pump manual also tells you to remove and clean this filter from time to time - so if your pump is like mine you will have to get to this filter. My filter is located on the back side of the pump as it is mounted.
