03-01-2015, 01:37 PM
Weight Distribution Sabre Silhouette 298RLTS
Tow vehicle: 2010 F350 6.4L Diesel, Crew Cab, Full Bed, Air Shocks on rear, single tire drive axle.
Trailer: 2014 Sabre Silhouette 298RLTS 5th wheel
Tire Pressures: steering axle 65 pounds
drive axle 80 pounds
trailer tires: 65 pounds
CAT Scale Results:
steering axle: 5420 pounds
drive axle: 5480 pounds
Trailer axle: 8380 pounds
Question: Do I have a problem pulling this load? I really do not understand this
load factor, especially calculating tongue weight (king pin on receiver).
Not real import question, however do the letters on my model mean anything
03-01-2015, 01:54 PM
this may help
Fifth Wheel Weight Calculator
This is a good to from our library here on the forum:
http://www.forestriverforums.com/for...do=file&id=129
Just a guess here, Rear Living Room Table Slide??
Mine stands for , Rear Seating Theater -Touring Edition - Champaine.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
03-01-2015, 02:08 PM
Rear living triple slide??
03-01-2015, 02:22 PM
Thinking you may be right
Seasonal
03-01-2015, 02:23 PM
Did you do a weight without the trailer by chance? A weight without the trailer will help you calculate exact trailer weight and pin weight as well as your available payload and adjusted towing capacity. Knee-jerk reaction without knowing more info is you are probably ok.
2014 Sabre 34REQS-6
03-01-2015, 02:26 PM
X2
Seasonal
03-01-2015, 02:40 PM
You can figure it out by looking at the 2010 Ford Towing guide......
Towing Guides | fleet.ford.com
Fonzie
03-02-2015, 10:39 AM
I want to thank everyone for your input. The next thing I will do is weight the tow vehicle loaded, minus the trailer. Thank you for directing me to the Fifth Wheel Weight Calculator. Will post results when done.
03-02-2015, 11:23 AM
Always Learning
When you weigh, try to get both weights at once (with the camper attached and truck alone):
Learn To RV: How to Weigh a Fifth Wheel Camper (at CAT Scales)
Then, you can plug them into my calculator here:
Actual Weights - Fifth Wheel Weights from CAT Scales - Towing Planner
03-17-2015, 05:29 PM
Just finished weighing tow vehicle only 2010 F350 SRW, long bed
Steer Axle: 5220
Drive Axle: 3440
GVW: 8660
Thanks to ependydog Actual Weights-Fifth Wheel Weights, results are as follows:
Truck and Camper Hook Up
Steer Axle: 5420
Drive Axle: 5480
Trailer Axle: 8380
Truck Only
Steer Axle: 5220
Drive Axle: 3440
Results:
Gross Combined Weight: 19280
Truck Weight (Hitched): 10900
Truck Weight(truck only) 8660
Camper Weight: 10620
Pin Weight: 2240
Pin Weight Percentage: 21.1%
Tire and Axle Loads
Number of Axles: 2
Individual Axle Weights; 4190
Individual Tire Weights; 2095
